VIN Numbers.
Discussion in 'UK Motorcycles' started by gazzafield, Mar 8, 2007.
  1. gazzafield
    gazzafield Guest
    Am I correct in thinking that if a Frame number is not fully visible it will
    now not pass an MOT? This could pose me a bit of a problem. MY PX200 that
    I am finishing up restoring to sell had a rather worn out number on the
    chassis. Now that it has been resprayed it has basically disappeared under
    the paint. How do I sort this? Teeps? (I have no idea of the correct
    spelling of teeps).
  2. gazzafield
    gazzafield Guest
    message
    That's my point. Even before it was painted half the number was just about
    gone and so faint as to be unreadable. I have no idea why. Italian
    craftsmanship I think.
  3. You need a chassis number for an MoT, yes. Just scrape the paint off it.
    The Older Gentleman, Mar 8, 2007
  4. gazzafield
    Steve Parry Guest
    In
    Can you get an plate made up with the number on it? My K has such a plate,
    attached with pop rivets, on the right frame member under the sidepanel,
    similar to a car chassis number plate.
    Steve Parry, Mar 8, 2007
  5. gazzafield
    Simon Wilson Guest
    Or get yourself some of these:
    http://www.justoffbase.co.uk/Number-Punch-Set-9pc-Sealey-AK9294?sc=9&category=340
    Very popular in the past for some strange reason, when number plates
    were easily transferred.
    Simon Wilson, Mar 8, 2007
  6. gazzafield
    gazzafield Guest
    Good shout.
  7. gazzafield
    gazzafield Guest
  8. gazzafield
    Steve Parry Guest
  9. gazzafield
    Not necessarily. I have a computerised MOT from last year with "Not
    Found" for the VIN.
    Same problem as the OP - over painted and worn out - the tester would
    have been happy to take it off the V5 but I didn't have that either.
    sweller, Mar 8, 2007
  10. I stand corrected.
    Oddly, I've seen a couple of ShiteOldSmallHondas that were never given
    frame numbers by the factory, and I have a vague feeling that right up
    until the 1970s or thereabouts Harley didn't stamp their frames either.
    <Googles>
    Yup, no frame numbers before 1970
    http://www.cyborgcycles.com/vinid.htm
  11. gazzafield
    Adrian Guest
    The Older Gentleman () gurgled
    happily, sounding much like they were saying :
    <points at '70ish VeloSolex 3800>
    No frame number on that, either. Yet the older 2200 does have.
    Adrian, Mar 8, 2007
  12. gazzafield
    Beav Guest
    But ffs, make sure before you smack the punch, that you're PERFECTLY in
    position and make doubly sure you only hit it once. Hitting it twice is piss
    easy and a double strike makes things look decidedly dodgy.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 8, 2007
