viffer brake problem
Discussion in 'Australian Motorcycles' started by Marty H, Dec 19, 2004.
  1. Marty H
    Marty H Guest
    Just replaced the rear pads in my 2000 VFR800 and decided to replace all
    the brake fluid.
    I have got the workshop manual and its says to use a "brake bleeder" and
    remove the old fluids first completely and then add the new...stuff that :)
    Decided to do what I have always done on every other bike of car I have
    had, buy a different colour brake fluid and just keep on bleeding until
    it changes colour.
    I have bleed all the 7 nipples and got the new fluid out of all of them,
    but I have a problem.
    30 seconds after I finished bleeding, the rear pedal goes to the floor
    and pumps fluid through the system like there is a nipple open, but
    there isnt, then over the next 30 seconds the rear reservoir fills back
    up by 5mm.
    pump the pedal a few times, down goes the reservoir by 5mm and over the
    next 30 sec it fill back up by 5mm.....and so one and so on
    have I stuffed up the bleeding procedure, or have I got a faulty rear
    master cylinder, if it is a faulty master cylinder are they serviceable
    items or a throw away item
    prolly explain why the rear brakes have always felt like crap too
    also, looking for a givi topbox rack for a 2000 VFR800 too, if anyones
    got one for sale
    Ta
    Marty H
  2. Yep, they come in pairs. You must've missed one!
    Pisshead Pete, Dec 19, 2004
  3. Marty H
    david Guest
    Does it have the front & rear braking systems linked ?
    David
    david, Dec 19, 2004
  4. Marty H
    Matt Palmer Guest
    Marty H is of the opinion:
    The problem with doing that is that you can often suck air back in through
    the open nipple if you don't get your timing quite right on the "open, pump,
    close, release" cycle. Having a reservoir of fluid to suck back in instead
    of air keeps the system air-free.
    That's air near the bottom end. What's happening is that there's a big-arse
    air bubble in there, and by pumping away you're compressing the air nice and
    tight (and perhaps getting a bit of pressure eventually), and then when you
    let it all go, the air is expanding and forcing the fluid back up into the
    reservoir again.
    I'd do a really proper bleed before assuming broken master cylinders (been
    there, done that). You can, in principle, rebuild master cylinders, but
    it's a fiddly, nasty little job, the spares will cost you a fortune, and
    it's most likely not worth it if you can grab one for a few bob at a
    wreckers.
    - Matt
    Matt Palmer, Dec 20, 2004
  5. Marty H
    SmeeR1100s Guest
    You haven't bled it properly.
    Do it again and make sure you have enough fluid in there when compressed.
    Your master cylinder is fine.
    As for a givi rack I got the rjay's top box and rigged up my own rack
    using a rewelded hallmark rack and a bit of ingenuity:) (Thanks Slej
    and Mick who welded the rack.)
    http://evilurl.com/butthumpPUSSY
    have a looksee
    SmeeR1100s, Dec 20, 2004
  6. Marty H
    Marty H Guest
    the 8th must be the clitoris...I always have trouble finding that!
    going to shed......trying the big air bubble scenario now
    mh
    Marty H, Dec 20, 2004
  7. Marty H
    stef Guest
    The solution is very simple - buy my Pegaso, then only ever worry about
    tweaking with 2 nipples !!
    stef, Dec 20, 2004
  8. Marty H
    John Littler Guest
    I'm sure you'll have no difficulty finding someone to tweak your nipples
    Stef, but buying you a pegaso seems a bit expensive !
    JL
    John Littler, Dec 20, 2004
  9. Marty H
    Conehead Guest
    A bloke I know calls his girlfriend "etch-a-sketch". He twiddles her knobs
    and draws a smile on her face
    Conehead, Dec 20, 2004
  10. Marty H
    Marty H Guest
    yup, sure does
    air somewhere in the master cylinder thats mounted on the front caliper that
    operates the centre pison of the rear brake.....getting there very slowly
    Marty
    Marty H, Dec 21, 2004
