VGA to TV advice
Discussion in 'UK Motorcycles' started by Hog, Oct 8, 2007.
  1. Hog
    Does anyone in the NG have experience of a good VGA to SCART converter to
    run this 'ere Vaio (vga out only) through a conventional analogue TV which
    has SCART and composite in only.
    I *think* I am right in assuming that connecting the vga directly to the
    composite will not produce a picture, or not a useable one.
    Hog, Oct 8, 2007
  2. Hog
    ginge Guest
    Whatever you do you'll likely get a horrible picture, standard PAL is
    only 720x576 @ 25 frames / sec.
    ginge, Oct 8, 2007
  3. Hog
    move to less pikey TV
    you think right - no picture whatsoever.
    darsy, Oct 8, 2007
  4. Hog
    It is only getting used as a music media center so that isn't particularly
    relevant. The screen is cracked and it isn't much use otherwise.
    Hog, Oct 8, 2007
  5. Hog
    antonye Guest
    http://www.idiots.org.uk/vga_rgb_scart/
    ASDA had the cheapest scart cable that I could find at
    the time for £2.97 but I've since seen 3-Way SCART boxes
    in the Poundland shoppe, so get one of them to butcher.
    The D-15 you can get from Maplins for £1.49 and another
    quid for the surround.
    http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=1310
    Or buy one ready made for £60
    http://www.maplin.co.uk/Module.aspx?ModuleNo=37141
    I've seen cheaper on ebay though.
    Just be aware that hardly any PCs will support the
    required refresh rates as standard, so you'll need to
    do lots of fiddling to get it working. There are plenty
    of instructions in the page lined above, but it may
    not be possible with your drivers.
    antonye, Oct 8, 2007
  6. Hog
    Bugger, beaten to it. Every decent telly these days has a VGA input,
    Shirley.
    And again. You're on form today, darsers.
    Pip, Oct 8, 2007
  7. Hog
    Andy Carvell Guest
    Also bear in mind that it'll only work for ATI cards, which rules out
    pretty much half the population.
    I got it working with my laptop which has a ATI xpress 200M. Took an
    awful lot of fiddling with Powerstrip though.
    Andy Carvell, Oct 8, 2007
  8. Hog
    Pete Fisher Guest
    This reminds me that I really ought to try and get the Network Media
    Receiver that came packaged with the PCV-RZ504 working again. I had a
    play before I got a router and became fed up with it because the peer to
    peer wireless with just a PCMIA card slotted in to the VAIO was so
    pitiful in range and in any case my main telly hadn't got the required
    red, white and yellow phono type connection things or S-Video. Did work
    though, and quite flash being able to stream TV from giga pocket
    capsules to the box and audio to my hi-fi, but a pain having to import
    any audio you want to stream in to SonicStage first.
    Not sure how to configure it to operate via the 3Com wireless router
    though. In any case, if the lappy to mother ship situation is a guide
    the signal strength will still be too low to be reliable where the main
    TV is (huge FOAD 'brindled' brick chimney breast in the way). I suppose
    I could hard cable it, which is probably the best option as I generally
    have the wireless switched off these days anyway.
    <goes off to RTFM>
    | Pete Fisher at Home: |
    Pete Fisher, Oct 8, 2007
