VFR750FK rear suspension linkage
Discussion in 'UK Motorcycles' started by M J Carley, May 25, 2010.
  1. M J Carley
    M J Carley Guest
    There is a bit of play in my rear suspension linkage which will be an
    issue at MOT time. According to the HBOL, this is usually due to worn
    pivots. Would any of you fine people know what Honda call the pivots
    on their assembly diagrams so I can order the new ones?
  2. M J Carley
    Jim Guest
    Bush, IWHT?
    http://zsf-motorrad.de/en/Spares/VFR750FK-E-MKH/F-25-REAR-CUSHION
    Jim, May 25, 2010
  3. M J Carley
    All depends on where you take it for an MOT. Some testers allow a
    little bit of play and some want it all rock solid when you try to move
    the link. Choose your MOT tester carefully.
    Lozzo, May 25, 2010
  4. M J Carley
    zymurgy Guest
    My 'storm failed on rear wheel bearing play. I thought bearings should
    have a little play, but the tester said otherwise :/
    Wasn't worth overly arguing the toss with, as I had a spare wheel in
    the garage anyway ..
    Paul.
    zymurgy, May 25, 2010
  5. M J Carley
    It shouldn't be easily noticeable for the MOT. If you can feel it
    there's too much play.
    Lozzo, May 25, 2010
  6. M J Carley
    M J Carley Guest
    It was an advisory last year. Best get it sorted.
  7. M J Carley
    In that case, most definitely, just for your own safety's sake.
    Lozzo, May 26, 2010
  8. M J Carley
    M J Carley Guest
    My thought exactly. The problem is that it is not too clear which bits
    I need. Looking at the picture:
    I think I need parts 28 and 30 and the dust seals to go with them. I
    don't really want to take out the linkage before I have the bits since
    I need the transport.
    M J Carley, May 26, 2010
