I need to replace the swing arm bearing(s) on my VFR750F-T, according to Haynes it sounds quite simple. Now I know Haynes can be misleading (it insisted that the centre stand had to come off to replace the exhaust, quite untrue) so I thought I'd ask here if anyone has done it. According to Haynes you basically get the bike on stands such that the rear wheel is just resting on the ground and then you can remove the bearings. I've had the bike suspended like this before, it's quite simple to set up a couple of axle stands under the rear pegs, so that's not a problem. Haynes doesn't mention any special tools or anything like that needed. I have a well equipped garage and can press new bearings in etc., no problems there. I'm just a little concerned that Haynes makes it sound so easy.
