VFR Servicing
Discussion in 'UK Motorcycles' started by SteveH, Jun 26, 2005.
  1. SteveH
    deadmail Guest
    (SteveH) wrote in message
    Plus gas the fucker and try again in a couple of days. It must be the
    rubber seal stuck, failing that try (some) heat. Hot air gun rather
    than a blow torch (maybe).
    Hot air gun again. Also try plus gas, WD40 is shite.
    deadmail, Jun 26, 2005
  2. SteveH
    Veggie Dave Guest
    Veggie Dave, Jun 26, 2005
  3. I share your pain, brother. Many's the time I've cursed the ham-fisted
    **** who'd replaced the filter before me.
    Grimly Curmudgeon, Jun 26, 2005
  4. SteveH
    gomez Guest
    When did they start making VFRs then?
    gomez, Jun 26, 2005
  5. SteveH
    I bought an identical oil filter tool to this:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=30917&item=7982237827&rd=1&ssPageName=WDVW
    the other week, knowing I had to do Elly's on the 9R and the car. I'd
    struggled a bit(1) doing a Bandit12 filter(2) a couple of weeks before
    - access is pretty crap on bikes generally and you can't get big grips
    in on cars like what you used to.
    There's some big serrated teeth on the jaws of this tool, that really
    bite into the filter casing and long handles mean loads of leverage
    available. Managed to get the filter off the 9R without removing any
    plastic, not even the bellypan. The Peugeot filter was stuck so tight
    that I know the assortment of chains and straps I have in the box
    would have either slipped round or cut through it - and that's messy.
    I'd recommend you try these pliers - they're even a pretty good price.
    1. A lot.
    2. Resorted to the usual small sharp cold chisel on the rolled-over
    base of the filter, picked up a little roll of metal and then hit it
    with a drift. This was after removing the bellypan, trying the
    proper-type removal tool, failing to get access through the headers
    with chain wrench, having insufficient space to turn the strap wrench
    and couldn't see how to turn the old screwdriver if I'd punched it
    through the filter.
    Pip, Jun 26, 2005
  6. SteveH
    Pip scribbled on the back of a napkin:
    They are rather good - that's the same type of pliers I recently bought
    of Halfrauds, the oil filters on my cars and bikes have found me
    irrestible since.
    Timo Geusch, Jun 26, 2005
  7. SteveH
    SteveH Guest
    Bought a set of those from Halfords - but there's not enough room to get
    a proper grip on the filter with them. They'll be handy for working on
    the cars, though.
    The old favourite of a 1/2 inch drive chain worked a treat in the end.
  8. SteveH
    deadmail Guest
    Hey, this is the safe option; I didn't say 'blowtorch'
  9. Heh. I thought of advocating that, before I considered the implications
    of using a blowtorch on a leaky oil filter.
    Don't forget - last time I used a blowtorch, I set my speedo cable on
    fire.
    The Older Gentleman, Jun 26, 2005
  10. I've got one of those - a decent chain wrench - and they're excellent.
  11. SteveH
    SteveH Guest
    Frustrating thing was that I had one in the garage all the time, but
    couldn't remember where I'd put it. Then it turned up once the job was
    finished.
  12. Ah, The Tool Fourth Dimension.
    Happened to me the other day with the Mini-Maglite.
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, SteveH
    I see you're sorted. I was going to suggest the technique used by one of
    the teams at Snetterton this afternoon. They very neatly removed their
    SP2's oil filter by the simple expedient of snapping a con-rod, so that
    the filter got punched clean off the cases by the flailing end.
    It all looked a tad spendy, especially given the "HRC" logo on the
    cases...
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jun 26, 2005
  14. SteveH
    Wicked Uncle Nigel says...
    I'm pretty sure all SP2s have HRC embossed on the cases.
    Lozzo, Jun 26, 2005
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Ah. Still won't be cheap though, eh?
  16. SteveH
    I doubt that very much.
    Lozzo, Jun 26, 2005
  17. SteveH
    SP Guest
    It's the gremlins, innit.
    You put a socket down next to you, pick another one up to do a job,
    reach back for the socket that was just there ----> and it's gone.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Jun 26, 2005
  18. SteveH
    In extremis. I find it a slightly uncouth and bloody messy way of doing
    it.
    sweller, Jun 27, 2005
  19. SteveH
    I've had one a Sealy oil filter grip/wrench things for some years and
    it's never failed me.
  20. SteveH
    I did that on my old mini - bloody hard to hammer the screwdriver through
    the filter. Then I discovered that the filter wasn't a spin-on canister
    type afer all, and that what I'd hammered the screwdriver through was
    actually a permanent, bolted on filter housing. Oops.
    platypus, Jun 27, 2005
