VFR 400
Discussion in 'Motorbike Technical Discussion' started by marcelminnaar, Jun 14, 2005.
  1. I have a little problem, I would drive my bike and then it would just
    cut out, dead, but the lights stay on and ignition lights stay on,
    then u have to start it again, it gets very anoing!
  2. What do you have to do to restart the engine? Does pulling the clutch
    level several times seem to help? Does turning the handlebars this way
    and that way help, Does putting the kickstand down help? Does putting
    the transmission in neutral help?
    You may have an electrical problem. A loose connector on the ignition
    control unit might be the problem. Also check the ignition kill switch,
    and the clutch, neutral, and sidestand safety interlock switches if
    your Honda has those.
    On the other hand, you might have a carburetor problem. What sound does
    the engine make when it quits? Does the engine just go "Br-r-r-r-r-r-r"
    as you roll to a stop. That's probably electrical, but if you roll off
    the gas to slow down and the exhaust sound is piffle-piffle-SNAP! or
    fartPOP! and the engine quits, that's dirty idle jets...
    I've described many many times here how to clean out dirty idle jets.
    Google for "kaybearjr@aol +EPA"...
    krusty kritter, Jun 15, 2005
