vf500C questions: Help?
Discussion in 'Motorbike Technical Discussion' started by Brent Evered, Oct 29, 2006.
  1. Brent Evered
    Brent Evered Guest
    Long time, no post.
    My brother dropped off his wife's 84 vf500c (v30) Magna to see if I could
    get it running properly for her over the winter. Major symptom was that it
    would not start/run. It left her Honda dealer mechanic in this condition.
    Said they were stumped, the bike was toast, offered her $400. Went over
    the obvious stuff and got it running, but although it would run on choke at
    idle for a while, it died when you open the throttle (low speed jets/dirty
    carbs, right?) Well the carbs had been allegedly cleaned. Turns out the
    narrower of the two fuel lines that run from the main tank (there's a
    secondary tank!!) was folded over on itself and completely pinched off.
    Say, I'll bet THAT would cause problems for the fuel system!
    Haven't had a chance to test with a new fuel line, but in looking over the
    machine, I note that the crankcase ventilation system tubes are all missing.
    This bike uses the main frame top spar as part of the system. Pipe goes
    from the rear right crankcase area into the empty frame, comes out at the
    front and goes into the air filter system. There's also an additional
    nipple on the back end of the frame member, that is supposed to connect to
    the standard drain pipe and plug system. None of these three tubes are in
    place, but all the nipples are there for the tubes. I note that this system
    is for the US models only, and that this is a Canadian model, but the holes
    are all there, including the vent into the crankcase. All my other canadian
    bikes have had a similar system.
    Question is, what do you suppose the symptoms would be of having this
    breather system open? A lot of mechanics (?) have had a crack at this bike
    over the years, and I can't be sure if someone forgot to re-install, or it
    was just never there?
    Thanks.
    Brent
  2. Brent Evered
    BobN Guest
    Brent, you'll have a better chance of getting an answer on the V4 Honda
    board: www.v4hondabbs.com .
    BobN, Oct 29, 2006
  3. Brent Evered
    Brent Evered Guest
    Thanks, bob. I'll give that a try.
