VF400F hoping for a miracle
Discussion in 'Motorbike Technical Discussion' started by oldgeezer, Aug 23, 2006.
  1. oldgeezer
    oldgeezer Guest
    Hi,
    Just hoping for a simple answer like 'throw some B-12 in your
    tank and be happy' but afraid that the final answer will
    be 'scrap the bike'.
    Here is what happened:
    I own a Honda VF400F, 1985. My only means of transportation.
    Nice bike, but impossible to service unless you are a Japanese
    midged with 3 feet long fingers and posess special Honda tools.
    I've driven a couple of miles with a flickering oil pressure
    light, making it to the next gas station.
    Replaced a simmer-ring, added 4 litres of oil, and noticed
    some miles later vibration in my foot rests at high revs that
    wasn't there before.
    I now have a knocking sound that seems to come from the
    front left cilinder. But only when I open up the throttle
    completely and the engine is hot. Not when the engine
    ran for a few miles (thus is relatively cold).
    Also top speed reduced from around 170 km/h to 120 km/h.
    And the oil pressure light is 'on' at idle when the engine
    is hot.
    My brain tells me: worn out cylinder or worn out crank shaft.
    But there is one thing that puzzles me: knocking goes away
    when I close the throttle a bit.
    I thought: Knocking may come from carbon deposit in a
    cylinder, and even though I am not a Japanese midget, I
    managed to take out all four spark plugs, but they looked
    very good.
    Any other ideas than 'scrap the bike'?
    Rob.
  2. oldgeezer
    oldgeezer Guest
    Mark Olson schreef:
    She blew out an oil seal (I called that a simmer-ring) and
    made a 4 mile trail of oil on the road before the light started
    flickering. I noticed the rear end was waving, but since it rained
    the first time after many dry weeks, I thought that to be the normal
    slippery of the tarmac at first rain, not a fouled rear tire.
    Checking oil level is a standard procedure to me, and easy
    because it does not have a dip stick but a small window in
    which you can see the level.
    The problem with this bike is that the crank case is the horizontal
    split type and the cililnders are part of the top half crank case.
    Even adjusting valve clearance takes about two pages in the
    service manual. Bleed the water, remove the tank, remove the seat,
    remove the radiator, remove the fan, remove the clutch, etcetera.
    To inspect my former beamers cylinder, I needed to unscrew 9
    nuts only. Did that many times, all in an hours work. This bikey
    will cost me a week to open.
    And I am scared to what I'll see then.
    Your answer is close to what I don't want to hear; 'scrap the bike'
    Ouch..
    Rob.
    oldgeezer, Aug 24, 2006
  3. Live with it. He's right.
    The Older Gentleman, Aug 24, 2006
  4. oldgeezer
    oldgeezer Guest
    Mark Olson schreef:
    My fault.
    I'm getting old. Ever since I was a kid, a simmer-ring was
    named simmer-ring (in the Netherlands). The word 'simmer'
    probably is German. I bet if I now ask a dealer for a simmer-ring
    he won't know what I'm talking about. Simmer-rings were those with
    a spring around the lip, 'olie-keer-ringen' (translated:
    oil-revert-rings) looked the same but had *no* spring.
    Simmer-rings were used for reciprocating things (like my clutch push
    rod that does not rotate but slides), the springless type were used
    for rotating axles (the ones with spring would -finally- wear a dent
    in the axle because the lip would rub the axle at the same place
    all of the time, of course the springless type would do that too, but
    much later).
    Like I said: I'm getting old..
    Not so long ago I tried to buy consistent-fat. The bicicle shop
    did not know what I wanted. It is now named bearing-grease.
    There aren't many around, it was an expensive little bikey when it
    was on the market. But they are around, so I should do what you
    suggest.
    To avoid going into the history books as a total moron; I was not
    asking a question like: "I drove miles without oil, and now I hear
    a strange noise, how come??"
    The oil light flickered, was not completely on, because I would have
    stopped immediately then. After the repair (oil ring) and fresh oil,
    she ran fine for a guessed 200 miles. Then I started to feel a fine
    vibration at my foot pegs, and a 100 miles miles later I started to
    hear a knocking sound.
    My guess: worn out cranck shaft main bearings.
    What made me wonder is that it does not knock when cold (it
    revs fine up to it's max 12500) but knocks when it is warm *and*
    I jerk the trottle open from a cruising 100 km/h. As soon as I close
    the throttle a bit (so that it does not have to accelerate but cruises
    again) the knocking disappears.
    Oh well.. The first thing I should do is to have a look at the
    innards of the engine. It's gonna be a long job with a sad end.
    Rob.
    No list of owned bikes here.. I'm too ashamed about the Ural.
