VF1000 sound
Discussion in 'Australian Motorcycles' started by ryan scott, Aug 16, 2006.
  1. ryan scott
    ryan scott Guest
    hey,
    i bought a 1985 vf1000 on sunday. is it normal for the engine to make loud
    popping sounds as i decelerate in gear? its a V4 engine.
    also, if i have the throttle opened a fair way, then let go suddenly, theres
    a large clunk sound, as if some gear cog is not tight in there.....or i
    might be the front forks but ihni.
    thanks
  2. ryan scott
    alx Guest
    Popping:-
    generic symptom of an air leak in the exhaust (eg gaskets at headers ).
    ALternatively, needs a service..
    Clunk...could be anything from... dud cush drive, loose steering head
    bearings, loose upper triple clamp bolt, ...not to mention gearbox probs.
    alx, Aug 16, 2006
  3. Standard or aftermarket sports exhaust? Altered jetting to make
    advantage of the exhaust?
    If aftermarket, it's probably unburnt fuel making it's way into the
    exhaust and exploding. Have a mate follow you at night to see if you
    get a nice blue flame to go with the pop.
    The clunk may be the 'spag?' clutch. The VFs of that era (at least the
    750s and 1000s) had a force limiting device to stop the rear wheel
    locking up if the engine decelerates fast or the rider drops it down a
    gear or two without matching revs. It makes a bit of a clunk as it
    activates.
    (kind of like the clutch you get on some drills to prevent you screwing
    something too tight)
    Rob.
    Robert Irvine, Aug 17, 2006
  4. My 84 "R" makes a clunk when you suddenly close the throttle too.
    Isaac.
    isaac_the_blind, Aug 17, 2006
