Vetter -Windjammer IV-Info?
Discussion in 'Motorcycle Technical Discussion' started by Tim C, Mar 20, 2005.
  1. Tim C
    Tim C Guest
    My recently purchased CB 650 has a windjammer IV fairing, and it is
    really clean shape. I ordered a new windshield, which came with all
    the new plastic screws and such. The foam surround is in good shape
    but flattened around the windshield installation area. Should I look
    for a new foam surround, or will it be ok to simply install the new
    windshield overtop of the existing foam??
    I have noticed that when I go over severe bumps that there is some
    vibration / clunks coming from the fairing, and even though it mounts
    with the 4 bolts that have rubber washers, I have thought that where
    the metal bracket mounts to the frame of the bike, could I use some
    rubber there to help dampen the vibrations?
    About the large headlight on this bike, there is an adjuster on the
    inside of the fairing with a turn bolt/cap to raise and lower the
    headlight. How do you adjust the side to side? Do you remove the ring
    of the headlight outside the fairing, to replace the bulb and what
    kind of dual filament bulb/wattage is in there? Is there a spec sheet
    for this fairing somewhere with a diagram of the parts and wiring etc?
    If you have an original owners manual for this Vetter fairing could
    someone scan it in and send it my way.....
    Thanks in Advance!
    Tim C.
    Tim C, Mar 20, 2005
  2. Tim C
    Calgary Guest
    I have emailed you a pdf file of a Vetter manual. Hope it will answer
    some of your questions.
    Don Binns
    2000 - Yamaha Venture Millennium Edition
    84 - Virago 1000
    You start with a bag full of luck and an empty bag of experience.
    The trick is to fill the bag of experience before you empty the
    bag of luck
    http://www3.telus.net/public/dbinns/reeky.htm
    http://www3.telus.net/public/dbinns/banff.htm
    http://www3.telus.net/public/dbinns/kananaskis.htm
    http://www3.telus.net/public/dbinns/walkercalgary.htm
    http://www3.telus.net/public/dbinns/calgarybrowning.htm
    Calgary, Mar 20, 2005
  3. Tim C
    Tim C Guest
    Thanks for the manual for the Vetter Fairing!
    This does answer what I needed to know and then some!
    Thanks Again!
    Tim C
    Tim C, Mar 21, 2005
  4. Tim C
    Calgary Guest
    All a part of the service I provide. :)
    Don Binns
    84 - Virago 1000
    bag of luck
    Calgary, Mar 22, 2005
  5. Tim C
    Popeye Guest
    If you have any more questions, ask Craig Vetter himself.
    http://www.craigvetter.com/index.html
    He still has some parts and whatnot available.
    brian
    Popeye, Mar 22, 2005
  6. Tim C
    Calgary Guest
    I think that is where I found the manual in the first place.
    Don Binns
    84 - Virago 1000
    bag of luck
