Veto Evo glitch
Discussion in 'UK Motorcycles' started by wessie, Jul 14, 2004.
  1. wessie
    David Nixon wrote in
    Have Liverpool Uni developed a time machine then? This post has come from
    the future.
    I think your problem is somehow linked to the words "Datatool" and "alarm".
    I had one in the past. Never again. Water got in and their customer service
    is shit. I was without a bike for 2 weeks.
  2. wessie
    Dr Zoidberg Guest
    They probably use NTL as their ISP.
    Alex
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.drzoidberg.co.uk
    www.upce.org.uk
    Dr Zoidberg, Jul 14, 2004
  3. wessie
    dwb Guest
    The System 3 is a much much better alarm.
    However it's fancy battery drain detector isn't that clever.
    If you disarm the alarm, it'll reset the voltage meter - which means if you
    happen to disarm the alarm a fair bit without riding the bike it'll still go
    flat.
    Getting an optimate sorted that out for me.
    dwb, Jul 14, 2004
  4. wessie
    Never having an alarm fitted on any bike I've ever owned has worked
    well for me over the years.
    Ace, Jul 14, 2004
  5. wessie
    David Nixon Guest
    My Datatool Veto Evo alarm triggered for no apparent reason, and
    I couldn't get the blessed thing to shut-off; save by disconnecting
    the motorcyle battery.
    The bike (Ducati) was recovered to a local dealer, who found no
    faulty alarm components - just a few slightly corroded
    connections. He suggested that maybe the battery
    voltage had dropped low enough to trigger the alarm, but I
    might consider upgrading the alarm PCB to the "System 3" revision.
    Anyone had similar problems with the Evo, or know
    if newer Datatool alarms are less of a drain on batteries?
    DaveN
    '95 GS500, 32K miles - offers around 500GBP, anyone..
    David Nixon, Jul 14, 2004
  6. wessie
    dwb Guest
    I'm not old enough to get a cheap enough quote with out one.
    dwb, Jul 14, 2004
  7. wessie
    Ace says...
    AOL. The Solalarm that was fitted to my T/ace now graces the bottle skip
    at the Black Horse in Hulland Ward.
    Lozzo, Jul 14, 2004
  8. wessie
    antonye Guest
    You don't say which model Ducati you have, but I know
    that the most common place on the 916 series to mount
    the DataTool gives problems as any water spray/rain
    runs down the lead and into the connector which is
    covered by a rubber boot? This holds the water in place
    and corrodes the connections sending it mad. I'm pretty
    sure this is the case as it's been discussed a few times
    over at ducatisportingclub.com
    The DataTools do seem to be crap alarms though, from all
    the reports of them either failing or not working in the
    first place.
    antonye, Jul 14, 2004
  9. wessie
    David Nixon Guest
    My Ducati is a 748R. I assumed that with the alarm
    being installed under the seat, it was in a hot &
    dry environment - but I will check to see if water ingress is
    indeed a problem.
    Thanks for that tip and to all who offered
    opinions about DataTool alarms in general.
    DaveN.
    Ducati 748R (with weedy 12AH battery) : Laverda 650 (gathering dust, but boasts
    a nice big 18AH battery )
    David Nixon, Jul 21, 2004
