Ventura Rack Broken
Discussion in 'Australian Motorcycles' started by James Mayfield, Aug 2, 2004.
  1. Was riding up to Kulnura the other day, and was travelling along the
    Gosford-Central Mangrove road. (Not sure what it's called.)
    And the bloody Venture rack snapped clean off.
    No provocation, just a slightly bumpy road. Bugger all load on it too!
    I'm not going to buy another one of those shithouse things. I'll invest in a
    pipe bender and make my own!!!
    Fortunately, there wasn't much traffic, and the R-Jays bag held up to it's
    tumble down the road at 100+ quite well. As did my IBM T30 laptop!!!
    (Luckily!!!)
  2. James Mayfield
    glitch1 Guest
    Not bad racks, really. But....seems that with age ( about 30-50.000km,
    regular use) they seem to weaken/ get brittle/ whatever and I've seen quite
    a few falling to pieces (usually the lugs fall off/welds separate).
    Thick-wall hydraulic pipe from Pirtek is good for that, comes in about
    Ventura-diameter, too.
    Ain't cheap though.
    cheers
    pete
    glitch1, Aug 3, 2004
  3. Define "ain't cheap"
    Are we talking $100 for enough to make a rack, or $1000 for enough to make a
    rack?
    James Mayfield, Aug 3, 2004
  4. James Mayfield
    FuTAnT Guest
    Bugger.
    I know it wouldn't look that good ... but ....
    a bit of trinagulation wouldn't go astray, and would definately strenghten
    the hell out of the racks. Just a small piece of steel rod going from the
    uprights to the support tubes down the side. I presume this is where they
    are breaking?
    Cam
    FuTAnT, Aug 3, 2004
  5. Actually, no. Mine broke just above the joint between the L brackets and the
    rack.
    You know the bit where they have a little indent in them for some reason
    (the indent ends up sitting _just_ above the top of the L bracket).
    Strengthening probably would have helped, as it would have reduced the flex
    in the whole thing.
    That is something I will be looking to address in my design for a
    replacement.
    Anyone have a pipe bender they want to lend me? I already have the welder.
    (Even if I do need to learn how to use it much better.)
  6. James Mayfield
    Mad Biker Guest
    Contact ventura, they replaced mine, even though it was out of warrantee...
    Im accually looking at strengthening mine somehow, any idea's?
    nat
    Mad Biker, Aug 3, 2004
  7. James Mayfield
    glitch1 Guest
    Made a complete rack (except for using a modified Ventura top-piece) from
    rear-footpeg-to-footpeg out of it, a 2. bar went from rear-grabhandle to
    grabhandle, some bracing as well, total about $100 in material.
    About $50 for enough material to make the L-brackets, plus about $10-15 for
    some flat-strap, guessing here...
    The rack itself is still ok, I guess... never seen one of those failing, so
    we're talking L-brackets only.
    cheers
    pete
  8. James Mayfield
    glitch1 Guest
    "James Mayfield"
    So, it was the actual rack and not the L-bracket.
    Strange...never seen that.
    pete
  9. Yep. If I can borrow a digital camera off someone in the next few days I'll
    put up some pics on a site, and post the link.
  10. James Mayfield
    smack Guest
    he's just admitted it was carrying an RJays bag..
    we'll dob him in
    smack, Aug 3, 2004
  11. James Mayfield
    Lushy Guest
    There was adead give a way to why it broke he was using a non veturer bag on
    the rack DER!!!!!!
    Lushy
    Lushy, Aug 3, 2004
  12. Bastards! Always one step ahead!
  13. James Mayfield
    Mad Biker Guest
    Their spy satalites would have picked you up anyway...
    but ill start applying for the warrents...
    Mad Biker, Aug 4, 2004
  14. James Mayfield
    SmeeR1100s Guest
    I'll supply you with a dictionary.
    SmeeR1100s, Aug 4, 2004
  15. James Mayfield
    Mad Biker Guest
    no such thing as that word
  16. James Mayfield
    Mad Biker Guest
    of course, the built in electronics didnt identify it to be a ventura
    quality bag, so it ejected it self from the bike to try and destroy it...
  17. James Mayfield
    Bobby Guest
    LOL
    Bobby, Aug 4, 2004
