VBG
Discussion in 'UK Motorcycles' started by Andy Hewitt, Mar 5, 2004.
  1. Andy Hewitt
    Andy Hewitt Guest
    Got out for about 30 miles today, took nearly an hour though as I was
    winding my way around the Durham moors (and got a bit lost).
    Fucking nice machine - was there an engine in it? It's so smooth I just
    had no idea what kind of revs it was at, even down at 1500rpm in the
    built up areas. Nice.
    The only thing that spoilt the ride, and inevitably shortened it, was
    the fact I need to adjust the gear lever. It took a while to get used to
    the clutch action as well, I'n not ridden with a hydraulic one before.
    Anyway, piccies here:
    http://www.thehewitts.plus.com/Newbike/Newbike.html
  2. Andy Hewitt
    'Hog Guest
    Hmm, nice.
    It seems inordinately clean, what year/mileage then?
    'Hog, Mar 5, 2004
  3. AvMph 30? did you get out of first gear?
    I can't remember what a dry clutch is like, I like wet clutches though.
    Having said that the wet clutch on the (exBlaney)Bandit is a real hand
    acher.
    Blimey, that's very shiny for a ukrm bike.
    Doesnotcompute, Mar 5, 2004
  4. Andy Hewitt
    'Hog Guest
    Photoshop
    'Hog, Mar 5, 2004
  5. Andy Hewitt
    It's not been a ukrm bike for long. Give it a chance.
    CT, Mar 5, 2004
  6. Andy Hewitt
    mb Guest
    Er, it's not a dry clutch, it's a hydraulic clutch.
    I can't remember what a cable clutch is like...
    mb, Mar 5, 2004
  7. I know.
    So the OP stated.
    That's what I said.
  8. Andy Hewitt
    mb Guest
    Oo, nice.
    I wonder why the oil filter holder isn't painted though? (Under the clutch
    slave cylinder).
    I thought they were all black.
    mb, Mar 5, 2004
  9. Andy Hewitt
    mb Guest
    I must be catching dyslexia.
    mb, Mar 5, 2004
  10. ITYM "stupidity" ;)
  11. Andy Hewitt
    Andy Hewitt Guest
    1991, 38k on the clock. It is very clean and shiny indeed.
  12. Andy Hewitt
    Andy Hewitt Guest
    Nope, didn't bother, these are raw from the camera.
  13. Andy Hewitt
    Andy Hewitt Guest
    LOL, yes, it won't look like that for very long.
  14. Andy Hewitt
    Andy Hewitt Guest
    After I've added a few scuffs you can :)
    Somewhere near the wind generators at Tow Law - I think (I did say I got
    lost).
  15. Andy Hewitt
    Andy Hewitt Guest
    <whoosh>
  16. Andy Hewitt
    Andy Hewitt Guest
    Not often, as I said the gear lever needed adjustment, so I didn't
    change any more than I needed too. Not only that, most of the roads I
    took (found) were 30mph anyway, and camera signs were
    every-feckin-where. Not knowing the area, I didn't take any chances on a
    snapshot.
    The BMW had a dry clutch, but cable operated, that was quite heavy. The
    FJ is hydraulic operated, and is very light - but the bite point is a
    bit short for me.
  17. Andy Hewitt
    mb Guest
    Sorry, I thought you were saying it was a dry clutch, but you just seem to
    have mentioned it in passing for some reason...
    Really? Where?
    mb, Mar 5, 2004
  18. Andy Hewitt wrote:
    Not only is the clutch quite heavy/strong, the biting point is approx
    1mm off the bars. So unless you've got it back and touching the bar, the
    bike is trying to move.
    Consider that I have the VS set the opposite way, so I only had to pull
    the clutch in about a quarter inch in order to shift down.
    Some contrast. And not one to forget which bike you're on.
  19. <sigh> the OP was commenting that this was his first useage of a
    wet/hydraulic clutch - ergo his previous experiences were dry/cable
    clutches.
    Where I said:
    Or am I being baited?
  20. Andy Hewitt
    mb Guest
    No, really. It's supposed to be black. Yours doesn't look like it's
    painted.
    Maybe a bit too much clutch fluid dripping on it from above.
    mb, Mar 5, 2004
Similar Threads
Loading...
