Valve noise?
Discussion in 'Motorcycle Technical Discussion' started by Phil, Squid-in-Training, Dec 3, 2005.
  1. I notice that my new (old) bike seems to idle nicely and quietly right after
    startup. After around 90 seconds and the engine warms up, what sounds like
    the valves begins to make a bit of noise at the front end of the bike. Is
    this really the valves working, or is it something else? It makes more
    noise when decelerating, but that could just be because the exhaust drowns
    out the noise.
    Previous owner always filled up with premium. I filled up with regular when
    the first tank got low about a week ago. The bike makes the same noise on
    the premium and regular.
  2. The fuel has nothing to do with it. It sounds like a sticking camchain
    tensioner.
    Telling us what bike it is might help.
    The Older Gentleman, Dec 3, 2005
  3. Phil, Squid-in-Training
    CK Guest
    I read complaints about "ticking noises" in the top ends of CBR-600's
    frequently. You might want to google around for CBR-600 forums that
    have discussed this problem.
    It just might be that oil on the valve buckets is thick enough when
    it's cold to take up clearances between the buckets and the cylinder
    where they slide up and down and that quiets the valve train until the
    oil thins out a bit because fresh oil is lubricating the valve train
    better.
    The cam chain gets lots of oil, it's better off than the drive chain in
    that respect, but it does live in a hellish environment of rapid
    acceleration and deceleration, with riders suddenly blipping the engine
    up to 12,000 RPM frequently just to hear the exhaust sound. It doesn't
    take much horsepower to turn the camshafts, but when the rider blips
    the throttle, he's demanding that the poor little chain take up any and
    all slack and *jerk* the camshafts into motion.
    Not smart at all. The chain link pins can wear, the chain can snap. My
    buddy's cam chain snapped during a heat race on Willow Springs once.
    The plastic chain guides wear too. You see tiny plastic shreds in the
    bottom of your oil drain pan while you're looking for metal chips
    indicating major problems.
    Chain guide wear is normal from the steel chain sliding hard against
    the miracle of plastic. Chain guides don't last forever, but there's
    enough plastic on them to go 100K miles. Most motorbike owners don't
    even know they have chain guides to wear out.
    The chain gets loose, the automatic tensioner is supposed to take up
    the slack, but it doesn't always manage to do that.
    Honda changed some part of the cam chain system in 1995, but I'm not
    sure exactly what it was. Maybe www.bikebandit.com has part numbers on
    their parts fiches and you can see what was changed. Www.partsfish.com
    doesn't have part numbers on their parts list.
    The automatic cam chain tensioner should be on the right hand side of
    the engine where the cam chain lives.
    Automatic cam chain tensioners like the CBR uses will have an access
    plug so the owner can push gently on the plunger and move it toward the
    chain, taking up any excess slack. Maybe if you do that you'll hear one
    or two clicks as the rachet pawl passes a tooth on the plunger. The
    ratchet pawl keeps the tensioner plunger from backing up.
    Before messing with the adjuster, you should accurately locate the
    source of the sound.
    If you run the engine and hear a rattling, but the rattling mostly goes
    away when you pull the clutch lever, that's the clutch basket. Maybe
    the big nut holding the clutch inner sleeve is loose.
    If the rattling doesn't go away, it's possibly the starter clutch on
    the left side of the engine. Broken bolts securing the starter clutch
    to the back of the alternator will allow the starter clutch to slap
    against the alternator.
    So, you have funny noises in your engine? Time to make a mechanic's
    listening device.
    Remove as much of the fairing as you need to gain access to the top and
    sides of the engine.
    Get an old wooden broom handle or a piece of 1-inch wooden dowel about
    1.5 feet long.
    The harder the wood, the better, it will transmit sound better.
    Start the engine and put the dowel against the cylinder head cover on
    the right hand side of the engine and put your ear against it and
    listen. Do the same thing on the left hand side of the engine, down on
    the alternator cover. Listen to the clutch by putting the stick against
    the clutch cover.
    You'll hear an amazing amount of clattering and grinding and rumbling
    sounds coming from the greasy guts of your engine. What does it all
    mean? The low frequency stuff could mean ball bearings are worn out.
    But the sharp, high frequency cracking sounds should give you cause to
    worry. Nothing in the engine is supposed to go snap, crackle, and pop!
    Well, if you were hearing pinging from low octane gas, it would be
    while you're accelerating, and it would take more than 90 seconds for
    the pinging to start. It would take more like 10 minutes for the engine
    to get that hot.
    CK, Dec 3, 2005
  4. As CK knew, '93 CBR600F2.
  5. Yes, a quick google search on "ticking CBR600" yields plenty of results that
    sound like my situation. They call it a "sewing machine" sound. Very
    characteristic of the noise.
    Hmm... that sounds plausible.
    37k miles on this '93.
    And that's all that needs to be done? Is the automatic one supposed to do
    all this for me, but I'm just helping it out a bit?
    The noise is definitely at the top of the bike.
    Great suggestion - I will try that one out the first time I get the bodywork
    off.
    Good to know. Plus I smell a hint of gas smell when I'm idling at
    stoplights. I wonder if it would be a slightly rich mixture, or if my bowls
    are in need of replacement/adjustment. The bike runs/idles nicely otherwise
    from idle to WFO.
    So the big question is: is a loose cam chain a really big deal? When it
    fails, does the bike just stop running due to no valve movement?
  6. Phil, Squid-in-Training
    CK Guest
    It's hard to say what that really means for a 12 year old bike without
    seeing it. Maybe it was used daily for 3 years and stored for 9 years
    or maybe it was only ridden a few weekends a year and spent much time
    in the garage.
    Yes, the automatic tensioner theoretically tensions the chain
    correctly. But sometimes the plunger will stick and it needs some help.
    You should also check the valve clearances to be sure that none of the
    valves is tightening up. You'll find the correct settings on a decal
    under the seat.
    A tight valve will burn. Use an American feeler gauge set to avoid
    going crazy with the metric gauges. The difference between blades in an
    American set is 1/1000th of an inch but the difference between metric
    blades is less than 4/10,000ths of an inch.
    I wouldn't go through the hassle of re-shimming a valve if it was only
    1/1000th of an inch too tight. But if it gets worse than that, the
    valve definitely needs re-shimming. The camshafts have to be removed to
    do that. It's a big job.
    And you can even get into trouble checking the valve clearances. We had
    a guy in here last summer complaining that he'd broken to part of the
    cam bearing cap that the valve cover bolted to. He was trying to torque
    the cylinder head cover bolts and they were oily. You can't torque oily
    bolts without risking breaking the bolt or stripping the threads the
    bolt goes into.
    The float valve might be leaking on one carb, or the float might be set
    too high or you might be smelling evaporated gas that recondensed in
    the charcoal canister and is dripping out the bottom of the canister.
    If you overfill the gas tank, you'll flood the canister and, again, gas
    drips out the bottom.
    Yes, a loose cam chain is a big deal. Besides the noise, the chain can
    kink, and even jump a sprocket tooth. If you look at the camchain
    diagram on www.partsfish.com you will see an upper chain guide that is
    supposed to keep the chain from jumping sprocket teeth, but if the
    chain is that loose it will be whipping around against the chain guides
    and making a rattling noise.
    If the cam chain breaks, the cams will stop with some valves wide open.
    The pistons will keep moving for many revolutions and the pistons may
    hit the open valves and bend them. Removing the cylinder head to
    replace bent valves is a major hassle. It gets worse if the valves
    damage the piston tops. The engine will have to be removed and taken
    completely apart, since the cylinders are an integral part of the
    crankcase.
    CK, Dec 4, 2005
  7. Phil, Squid-in-Training
    John Johnson Guest
    ISTR some articles in Bike (UK magazine), about Honda's automatic
    cam-chain tensioner often going out pretty early. On some models (e.g.
    VTR1000) people pretty commonly replace it with a manually-adjustable
    version.
    Phil might want to check online for evidence one way or another whether
    this is an issue on this machine. Evidence might be the easily
    availability of manual cam-chain tensioners for his bike and/or web
    pages detailing the replacement of the tensioner. It's worth looking
    into, if web access is easy.
    Later,
    John
    John Johnson, Dec 4, 2005
  8. In which case it is almost certainly a sticking camchain tensioner unit.
    The CBR600 is notorious for it.
    Very easy and cheap fix.
    The Older Gentleman, Dec 4, 2005
  9. Utter nonsense
    It's a sticking tensioner, I bet.<snip
    It's a sticking tensioner. Google for CBR600 = sticking + cam + chain +
    tensioner and you get a shedload of hits, all describing the symptoms
    and cure.
  10. It's a sticking camchain tensioner - just in case you didn't get the
    mesage ;-)
  11. OK, guess who I write for?
  12. Phil, Squid-in-Training
    John Johnson Guest
    Hmmm.....T.W.O.?
    I gotta say, Bike is a fantastic magazine. I used to read Cycle World
    all the time, but after looking at the British magazines it just didn't
    hold my interest any more. I was also rather irritated that CW never did
    gear comparisons. Now I'm irritated that I have to wait until mid-month
    to get the current issue! lol
    I keep thinking that someday I'll look around here for a newsstand that
    carries Motorrad, and see how they stack up, but I never seem to get
    around to it. So I stick with Bike.
    Later,
    John
  13. Motorrad is *superb*. Bike has taken a lot of cues from Motorrad in
    recent years, especially on the technical side. Unfortunately, I don't
    speak German.
  14. Phil, Squid-in-Training
    remove Guest
    When you do replace that cam-chain tensioner, I'd suggest using an
    aftermarket manual CCT (from APE) in place of the Honda OEM part. It's
    a set and forget affair and will never need replacing. Cheaper than oem
    too.
    remove, Dec 4, 2005
  15. Phil, Squid-in-Training
    John Johnson Guest
    lol. Well, my german could be better. I'll poke around a bit over the
    semester break, maybe. In the meantime, the Dec. issue of Bike should
    show up here in another week. I'll just have to read back-issues until
    then, I guess. Given the new Daytona 675, that's not hard to do really;
    I just stare at the pictures. ;)
    Later,
    John
    John Johnson, Dec 5, 2005
