Valve Job: Lapping-in Valves
Discussion in 'Motorbike Technical Discussion' started by Manjo, Jan 25, 2006.
  1. Manjo
    Manjo Guest
    I'm doing a top-end job on a 1995 Kaw Vulcan 1500A V-twin. The valves
    have about 100k miles. A leak-down test showed 10% loss last year and
    %15% loss this year in both jugs, so it looked like it wa's time to
    check and fix thngs.
    Looking at the valves and seats, I saw pitting on all 8 sets. The
    exhaust valves seem to have experienced the worst wear. I've miked the
    valve stems and did a "wobble" test on the valve guides and both were
    in spec on all valves (much to my surprise).
    I've miked the valves seats and they are a little wider than spec by
    about 0.25 mm on all four exhaust valves after hand-lapping the valves.
    My question is, will the bike run OK with these slighty wider seats,
    or do I have to gind the seats to make them narrower?
    TIA for tips and suggestions,
    Manjo
    Manjo, Jan 25, 2006
  2. Manjo
    oskar Guest
    The racing guys like to run really narrow valve seats to increase the
    point pressure of the valve seal. Narrower seats are easier to burn
    than wider seats because they can't get rid of the heat. I would just
    call it an endurance valve job and reassemble the motor.
    oskar, Jan 25, 2006
  3. Manjo
    alan&alon Guest
    yes its not to good to have a wide seat as a narrower one is less likly to
    get burned or filled with carbon deposits i would suggest to get the seats
    cut your local machine shop should be able to do this as well as the dealer.
    also put rings in as with the added valve pressure will make more leakage
    past your rings and cause it to suddenly burn oil rule of thumb dont do one
    without the other.
    alan&alon, Jan 26, 2006
  4. Manjo
    Ron Seiden Guest
    Whenever we used to work on an engine, we figured it was a good idea to lap
    the valves as long as the head was off & on the bench anyway. How much they
    got lapped depended on their condition -- even just smoothing out that
    pitting would be a good thing.
    Ron Seiden, Jan 26, 2006
  5. Manjo
    Manjo Guest
    oskar, alan, Ron, and Nomen,
    Thanks for the replies, tips, and suggestions.
    I have all the valves lapped in and will go for "endurance". I also
    have new valve oil seals for all the valves.
    One thing has developed that looks strange to me. On both rear jug
    exhaust seats and corresponding valves, concentric circles/ridges have
    developed where the valve meets the seat. Of the eight(8) seats, these
    are the only two where these circles/rings have developed (these are
    also the two seats that had the most pitting, needing the most work).
    I'm prone to just reassembling the headed and look for leaks. I'm
    concerned that I've done something wrong. Should I do more lapping to
    get the rings out??
    Anyone seen rings like this before? If so, what was done to get rid of
    them, or can they be lived with?? Your suggestions are appreciated.
    TIA for your help,
    Manjo
    Manjo, Jan 27, 2006
