Valve clearence tools
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 29, 2005.
  1. I'm still putting off doing it.
    I thought I'd plucked up the courage to do it but in the HBOL it says
    "to make the task easier use the Honda parts"... Yeah, right, a spanner
    and screwdriver will do it, BUT, it says on the thou models, like mine,
    I'll need a 3mm allen key cut down to 65mm-68mm.
    WTF's *that* all about?
    I can't see or imagine anything in there that will require "specialist"
    stuff but I don't want to be pulling my engine to bits and then have to
    leave bits strewn about on the garden[1] because I can't finish the job.
    [1] More like a dirt patch with sprigs of grass and weeds.
  2. Whinging Courier
    YTC449 Guest
    Clearance/Access in restricted space?
    Get a man in
    Garden or Flat?
    Robbo
    Trophy 1200 1998
    BotaFOF #19. E.O.S.M 2001/2002/2003/2004/2005
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    YTC449, Oct 29, 2005
  3. In uk.rec.motorcycles, YTC449 amazed us all with this pearl of wisdom:
    That's one option but I'd rather do it. 'Slike brake pads, innit, you
    don't realise what a piece of piss it is until you do it yourself.
    Both :)
    [1] Not started on them yet. Decided to sort my car out first.
  4. Whinging Courier
    scruttocks Guest
    You need a long series 10mm socket for the lock nuts and an allen key
    longer than the socket to twiddle the adjuster, normal length allen keys
    do the job. I ground flats on the side of the socket so it could be
    turned by a spanner.
    Crack the locknuts, stick the socket on and twiddle the adjuster using
    the allen key down the middle of the socket, nip it up using the spanner
    when correct and then finally torque using the socket with a ratchet on
    it (or torque wrench if you're feeling glamourous).
    You can rotate the tank horizontally and rest it where the seat should
    be to save disconnecting all the plumbing.
    Hope that makes sense.
    scruttocks, Oct 29, 2005
  5. In uk.rec.motorcycles, scruttocks amazed us all with this pearl of
    wisdom:
    OK, I think I got that. The Haynes manual shows a ring spanner and a
    screwdriver, that's what got me curfuddled about the allen key!
    I was going to do them "that's tight enough" tight since my torque
    wrench got nicked/lost/abandoned.
    That's a good tip, actually, thanks.
