valve clearances 1998 CBR600F
Discussion in 'UK Motorcycles' started by steveonholiday1, Dec 15, 2007.
  1. Hi,
    I've just bought a 23,000 mile CBR600F - my first bike with shims -
    the GSX600F I've had for 10 years has screw adjusters. I've checked
    the valve clearances and they are on the service limit...
    Haynes says 0.19-0.25mm for the exhausts - I have two valves which
    allow the 0.18 gauge through, but not the 0.20 gauge. i.e. they are
    either 0.18 or 0.19mm
    Removing the cams is a 4-spanner task according to Haynes so I'd
    really like to avoid it.
    What is the percieved wisdom among the home mechanics with experience?
    (not the 'just take it to the garage and pay the bill' people) Should
    I go to all the effort of fixing it, or leave it?
    I plan to keep the bike forever, and maybe never check them again (I
    was told the clearances hardly ever change on this engine by a
    mechanic who is usually over cautious if anything)
    Cheers for any learned opinions
    Steve
  2. steveonholiday1
    I'd adjust them. If you don't do it now, you'll almost certainly have
    to after another 10k miles, & possibly a lot sooner. If you don't
    adjust them you'll just have that nagging doubt, & end up checking them
    again in a few months anyway.
    It's not a difficult job, just time consuming.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Dec 15, 2007
  3. steveonholiday1
    says...
    If the clearances have gone tight then get those two you mentioned
    sorted. Your mechanic is kinda right, CBR600 clearances rarely go out by
    much, but it's worthwhile doing them if you want to keep the motor good.
    If you've checked them then I assume you have the cam cover off, so
    actually changing the shims is just the next step on. It's not that
    difficult if you know what size shim you have, what valve clearance that
    shim gives and what shim is required to get the clearance back to where
    it should be. In the manual there should be a chart that lists the
    correct shim if you know the first two values. You do have to be careful
    of timing up the cams once you replace them and making sure you torque
    the cam cap bolts to the specified value. The rest is 2 spanner work.
    Timing up the cams is made easier by tightly cable tying the cam
    sprockets to the chain before removing them, making sure you never turn
    the engine while they are out. Always treble check the cam timing is
    correct before slowly turning the engine by hand after reassembling the
    cams, and camchain tensioner, but before you replace the cam cover. Only
    finish the reassembly and attempt to start the engine once you are
    satisfied that everything is back together correctly.
    Get stuck in and do it.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Yamaha SR250 SpazzTrakka
    Suzuki GSX-R750L
    Lozzo, Dec 15, 2007
  4. Those clearances you quote really are on the tight side, so I'd get it
    done properly.
    That's true, but if I was going to run it for ages and ages, I'd want to
    make sure it was running spot-on clearances to start with.
    The Older Gentleman, Dec 15, 2007
  5. Those clearances you quote really are on the tight side, so I'd get it
    Thanks guys. It's the answer I didn't want, but that doesn't make it
    wrong!
    Looks like I need to bite the bullet and sort them :-( Bollox. I
    was all comfy on the sofa...
    Thanks for the guidance Lozzo. I'll be really careful. (I managed to
    recently destroy the wifes Fiesta engine with a rather unfortunate
    valve on piston incident...) <hangs head in shame>
    Cheers,
    Steve
  6. steveonholiday1
    Alan Crowder Guest
    I did this also, did not listen to my Ford Mechanic who said Zetec engines
    come out of the bottom, bollox said I, the older type came out the top and
    by undoing the bottom pulley wheel so did the Zetec, but alas it has no
    woodruff key and the timing chain slipped, whoops.....bent valves.
    Alan
    Alan Crowder, Dec 15, 2007
  7. steveonholiday1
    says...
    I've just had a quick flick through the workshop manual. You only need
    to remove the exhaust cam, the inlet can stay where it is. On some
    bikes, later Gixers for example, the cam caps are one huge item that
    clamp both cams down in one hit - on the CBR you have two seperate ones
    for inlet and exhaust.
    The Haynes manual tells you to remove the sprocket from the end of the
    exhaust cam before taking it out, you *may* not have to do this. First
    remove the 3 bolts holding the cam chain top guide in place, then like I
    said, cable tie the sprocket to the camchain on both inlet and exhaust
    cams to stop it from moving, undo the exhaust cam cap bolts in the
    correct order as shown in the book and see if you can just roll the
    exhaust cam up and backwards to keep everything attached, making life
    easier when it comes to putting it all back together. It might not be
    possible to simply move the cam up and back with it all cable tied in
    place, in which case just follow the manual and remove the sprocket.
    Either way, it's not rocket science and only adds about 20 minutes to
    the job, it's just my way saves on pointless arse-ache if it can be done
    that way.
    Once the cam is out of the way, all you need to do is lift out the
    buckets from the ones that need attention, take the offending shims out
    and swop them for the correct ones, then reassemble. Just make sure you
    don't turn the engine over while the cam is out and treble check the
    valve timing before you refit the cam cover.
    Lozzo
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Suzkui TS50X
    Lozzo, Dec 15, 2007
  8. steveonholiday1
    deadmail Guest
    Not forgetting to stuff clean rag into the cam chain tunnel etc. to stop
    stray screws and what have you being dropped in there.
    deadmail, Dec 15, 2007
  9. steveonholiday1
    says...
    Not so bad on CBR6s because the camchain tunnel is at one end. Simply
    remove the right hand engine cover and retrieve the lost bits.
    Lozzo
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Suzkui TS50X
    Lozzo, Dec 16, 2007
  10. steveonholiday1
    <shock>
    It is???
    Is your 1100 a little tired?
    In what ways is the Honda superior.
    Hog, Dec 17, 2007
  11. steveonholiday1
    deadmail Guest
    I don't think so.
    Reversing the question, the screen and fairing on the K is far
    superior... but that's it.
    The Pan wins on:
    - Handling.
    - Suspension.
    - Braking.
    - Riding position.
    - Stability (K1100 is top heavy when fueled and is tall).
    Face it, the K harks back to the early 80s whereas the Pan is a decade
    younger. It shows.
    The engine *might* be a little better on the K. Not really sure.
    They're both nice and tractable.
    deadmail, Dec 17, 2007
  12. steveonholiday1
    They need modding I agree
    Upgrading makes all the difference but costs a few bob
    This makes me wonder. The K11 with good disks, goodridge hoses and the right
    pads should be about the best brakes you ever tried.
    Hmm I found the standard K11 bars too high and set back too. The footrests
    slightly too far forward.
    Relates to the suspension issues.
    Improved again with RS size wheels and good radial tyres.
    Hog, Dec 17, 2007
  13. steveonholiday1
    deadmail Guest
    Not with those long forks and rubber mounted handlebars.
    Yes... but the Pan doesn't need any mods; that's the point...
  14. steveonholiday1
    That doesn't change the braking characteristics though does it?
    I'm repeating myself but a Hagon or Progressive fork conversion (or a trip
    to Maxton if you are flush) and fixed mount bars cures *so* much.
    Actually I would love to do a factory trip to Maxton with a K11. I recall
    Monz doing this with the TL1000 and it cost him about a Grand so it would
    need to be a late and mint K to be worth the expense.
    Oh I realise this but I never liked the fairing, the handling, the
    complexity, how hard it is to work on, the spares situation (in comparison)
    and it's a Honda...
    Hog, Dec 17, 2007
  15. steveonholiday1
    Brakes work better than they did, for sure <eyes RD400> but my K11 was like
    hitting a brick wall, not quite in the AP class but good nevertheless. The
    bar or suspension never made me think they were anything other than great.
    To be sure, until the rubber bar mounts were shimmed out it could snake
    under you some.
    Hog, Dec 17, 2007
