Valve Clearance Question: 1984 KZ550 LTD
Discussion in 'Motorbike Technical Discussion' started by TwoWheelHeather, Jan 23, 2006.
  1. Hi Everybody,
    I bought an old non-running KZ550 LTD, from trustworthy-seeming guy
    that told me it had been on the road a couple of years before, but had
    carburetor issues.
    I pulled the carbs and de-gunked them, being careful to clean all the
    jets & needle/seat. When I put it back together (it was a major pain
    with all the hardened rubber, it would start & run, but only with the
    aid of starting fluid. Once warm, it would idle on 2.5 cylinders, but
    would run well on the mains at higher rpms/load. The #3 cylinder
    appears not to be firing at idle (based on my scientific hand against
    hot header test).
    I checked the valve clearances, and the #1 & #4 exhaust valve
    clearnaces are running around .11mm when the spec. is .15mm-.20mm.
    Seems to me that .05mm out of spec wouldn't cause the hard starting
    problems I'm having-- also the #3, which seems to be the problem, is
    in spec.
    I pulled the pilot blanks & screws and de-gunked with B-12 chemtool and
    blew out with compressed air. If anything, the bike has gotten worse
    after the pilot circuit clean out.
    My main question: is it more likely than not the valve clearances are
    causing the problem? I would like to get the bike running before
    spending the money to get the valves done (or doing them myself).
    On this bike the cams need to come out after the cam chain tensioner
    plunger is depressed which appears to necessitate removal of the
    carburetors. Have I mentioned that I'm beginning to hate working on
    this old bike?!?! Have I?!?!
    Thanky!
  2. I would be suspicious of the ignition system. The ignition system
    probably uses two coils for that engine. You may have a weak coil that
    only produces an adequate spark at high rpm. At low rpm, the spark is
    too weak to sufficiently fire the air/fuel mixture.
    charles
    mad scientist, Jan 23, 2006
  3. While attention to the carbs is a good idea, I can promise you that
    over-tight valve clearances does indeed make for hard starting. I'd get
    them re-set.
    The Older Gentleman, Jan 23, 2006
  4. Hi Guys,
    I am getting spark on the #1/3 cylinders, but was noticing yesterday
    the #3 was a bit orange... I'll get one of those air gap testers and
    check it out.
    Hey, I have a 1976 CB400F - Parakeet Yellow (apparently before the days
    of canary yellow). Beautiful bike, fits me perfectly!
    I guess there's no way to know whether a clearance of .11mm on a .15mm
    spec would cause starting trouble. Was just thinking that .04 out of
    spec would be something you'd encounter during normal operation between
    inspection periods.
    You all are holding my feet to the maintenance fire, ain'tcha?
    Thanks!
  5. TwoWheelHeather
    John Johnson Guest
    It seems to me (no expert on these bikes) that if you've got a weak coil
    causing the 1.5 cylinders to miss, swapping coils should cause the
    cylinders in question to fire. Or, if you're getting a tester anyway,
    compare the spark in a cold cylinder to that produced in a good one.
    You could get your valves back in spec and see whether the starting
    trouble remains...
    Later,
    John
    John Johnson, Jan 24, 2006
  6. Have I mentioned the cams & possibly the carbs have to come off to set
    the valves? :) Isn't there some sort of gas additive or perhaps new
    sparkplug wire that will make all of my troubles disappear? *removing
    tongue from cheek*
    TwoWheelHeather, Jan 24, 2006
  7. TwoWheelHeather
    John Johnson Guest
    Yeah, and I sympathize. I've got a '94 VFR with shims under buckets, so
    if my valves need adjusting, I've got to do the same thing. I don't have
    to worry about the camchain, though, which is nice. ;-) Still, suck it
    up and do the valves is my advice.
    Later,
    John
  8. The carbs don't have to come off, no.
    The cams have to be displaced, yes, but not totally removed. The valve
    shims are under the buckets.
    To displace the cams, undo the camchain tensioner (two bolts, back of
    the block). Then zip-tie the camchain to the cam sprockets, passing the
    ties through the holes in the cam sprockets. That way you never lose the
    cam timing.
    Then all you need to do is shift the cam sideways while you pull out the
    bucket and shim.
    Top tips: rag, lots of rag, stuffed into every crevice. You do not want
    to drop a shim into the engine. Also, be very very careful when
    re-bolting on the tensioner unit. It just needs to be nipped up, and
    even tightening to the low (recommended) torque can strip the threads.
    DAMHIKIJK,OK?
    The Older Gentleman, Jan 24, 2006
  9. TwoWheelHeather
    alan&alon Guest
    the carbs are still not clean they need to be totally dissassembled and
    soaked in a commercial carb solution and put back together with new rubbers
    and gasket and possibly new float valves the valve being out of spec is not
    your starting problem or running theirs alot of passages in the carbs that
    you cannot get unless their soaked. i dought your ignition is the problem
    either.
    alan&alon, Jan 24, 2006
  10. Actually, sweetie, valves being too tight really *does* cause starting
    problems. Although I agree carb troubles are more likely.
    The Older Gentleman, Jan 25, 2006
  11. Thanks, guys. As between the carbs and the valves, I would prefer to
    tackle the job most likely to get the bike started and running.
    I do understand how valves will make the bike hard to start-- I just
    didn't know if .11mm clearance on a .15mm spec would cause the hard
    starting problems, and it seemed like someone would know whether it
    would.
    So, first the carbs come back off-- maybe take them someplace to get
    them cleaned, and then if the bike still doesn't run, the valves will
    get done.
    Regardless, the valves will get done-- just hate to do the valves only
    to find out I can't get the carburetors right and the bike is a
    write-off.
    Thanks, all!
    TwoWheelHeather, Jan 25, 2006
  12. TwoWheelHeather
    John Johnson Guest
    My advice would be to do them yourselves unless you know, absolutely and
    for certain, that the guy who will be doing them knows his/her stuff and
    will _actually_ do the job right. While my experience with such things
    is limited to one crappy mechanic, I've heard too many stories that
    match up with mine: paid lots of money to a professional who either
    muffed the job or (what I suspect happened in my case) simply didn't do
    anything. It's not hard to clean out a carburetor, you just have to be
    patient and accept that no corners can be cut. The procedure has been
    posted here hundreds of times in the past, so check the archives.
    Later,
    John
    John Johnson, Jan 25, 2006
  13. TwoWheelHeather
    alan&alon Guest
    acually older sweety if it has some clearance the valve is closed at startup
    their for having no affect. when warm is wear a tight valve will show up
    exspecialy at idle
    alan&alon, Jan 26, 2006
  14. You're wrong. Sorry, but you're wrong. It varies in effect from bike to
    bike, but trust me - over-tight valve clearances degrade starting
    performance.
    My own 1200 is *particularly* susceptible to it - it's a known Trophy
    issue
    Have a look at
    http://www.motorcycle.com/mo/mcdirt/trailrider/toolbox2.html for another
    mention.
    Now go away.
    The Older Gentleman, Jan 26, 2006
  15. TwoWheelHeather
    alan&alon Guest
    ive read your artical and yes it can cause hard starting (i beleive their
    talking about a hot startup}if the valves are neglected however this would
    be a severe case to where again their is NO clearance and acually holding
    the valve open ever so slightly then i could see poor starting issues along
    with a lot of other running problems. i am not wrong on this i have worked
    on motorcycles my whole life i know what im talking about. im currently a
    certified tech. with more factory training then i can stand funny you should
    mention your triumph i am a factory trained triumph tech i have been to the
    triumph school just south of atlanta at least a dozen times.yes i was in the
    dealership back when the trophy 1200 came out. ive worked on kaw for at
    least 25 years. also very high up the ladder in harley and buell training.
    do some checking into this if you want prove to me that im wrong and ill
    admit to it. also think of this hydralic lifters hold vertualy a ZERO
    clearance at start up. but they in no way hold the valve open. again i
    beleive if the valve has some clearance it will not affect startup. it will
    however if the clearance is very little on solid rockers as the engine gets
    warm the clearance goes away and can affect idle and a WARM OR HOT startup
    depending on how little clearance the valve has at cold startup. ps we
    should be receiving our new triumph 675 tommarrow.
    alan&alon, Jan 27, 2006
  16. Well, yes. But it's still an issue.
    Thank you. That is what I said. Incorrect (too tight) valve clearances
    *can* affect starting. I agree it's rare, though - but my Trophy is
    certainly one that is so affected, and I know of two others that have
    the same complaint if the valves get out of spec, and my local Triumph
    dealer admits it's an issue on them.
    Now there is a nice-looking bike.
    The Older Gentleman, Jan 27, 2006
  17. TwoWheelHeather
    messenger1 Guest
    I recently spent an inordinate amount of valuable time cleaning my carbs
    over and over again,after having mistakenly assumed they were the cause of
    my hard starting issues. My bike would absolutely not start unless I put a
    cover over it and stuck a small space heater underneath it for an hour or
    so. On the advice of a fine fellow at oldbikebarn's tech forum, I checked
    and adjusted the valve clearances on my 85 GPz900R and lo and behold, it now
    starts like a new bike again, even in our -15C weather!
    messenger1, Jan 28, 2006
