Vacuum feeds linked together. Good idea?
Discussion in 'UK Motorcycles' started by adamgamsa, Nov 11, 2008.
  1. adamgamsa
    adamgamsa Guest
    Hi all,
    The question's about a 1987 Kwak gpz400r, which is a liquid cooled
    four cylinder four stroke. It's got a vacuum switched fuel tap, and so
    takes a vacuum feed from the inlet rubbers. This is done in a bit of a
    weird way. The inside pair of cylinders have the vacuum feeds linked
    together into a T-piece, the other pipe in this junction then goes to
    the fuel tap. The outside two cylinders have a single length of pipe
    connecting their vacuum feeds together, doing nothing else. I can't
    decide (and don't know) what the point of all this is, or if it is
    effective in doing anything. Surely it's not to compensate for if the
    carbs get out of sync or something? The jets on the outside carbs are
    different to those of the middle two, so I understand why all four
    aren't linked together.
    What I propose to do is sync the carbs properly, blanking off the four
    vacuum feeds and to change the fuel tap for a standard (non-vacuum
    shutoff) type. If this is a really bad idea, please can someone warn
    me? Anyway, I know you guys have seen it all on this thread, so it'd
    be nice to get a better idea of what this is all about.
    Cheers for any help you can offer,
    Adam
  2. adamgamsa
    TOG@Toil Guest
    The point is that all the carbs are identical, right? It makes no
    sense to manufacture some carbs with vacuum feeds and some without, as
    it just puts up the production costs. So you blank offthe vacuum feeds
    on the carbs that aren't connected to the fuel tap.
    Also, are you *sure* the outside carbs are jetted differently to the
    inside? I'd be surprised if that were the case.
    Nothing wrong with using an ordinary gravity feed fuel tap, by the
    way. Understand, though, that the vacuum take-offs for the fuel tap
    are not the same as the vacuum take-offs for carb synching. Those are
    separate.
    TOG@Toil, Nov 11, 2008
  3. adamgamsa
    It's not uncommon to find the inner two cylinders are jetted slightly
    larger to compensate for running slightly hotter. RGV250s run a larger
    jet in the left (rearward facing) cylinder for this reason too.
    Lozzo, Nov 11, 2008
  4. OK, fairy nuff. I've come across bikes with different plug heat ranges
    on the same engine, so I suppose I shouldn't be surprised at different
    jetting.
    The Older Gentleman, Nov 11, 2008
  5. Often is - the middle two cylinders run hotter and often have a
    different jetting or needle position.
    Grimly Curmudgeon, Nov 12, 2008
