Vacum Gauge damper screws
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, Sep 3, 2009.
  1. I have acquired one of these super, whizzo mercury carburettor gauge
    doo dahs. It had no rubber pipes or adapters with damper screws
    though. Does anyone have any idea where I could get these from?
  2. rufty_tufty_hoolythug
    TOG@Toil Guest
    The dampers are just little plastic tubes with screws that restrict
    the flow through them, that's all. I'd have thought you could achieve
    exactly the same effect by buying four small G-clamps, and using them
    on the rubber tubes (when you get them).
    Don't forget you also need the metal adaptors that screw into the
    vacuum take-off points.
    (Used my gauges on the 400 Four last weekend....)
    TOG@Toil, Sep 3, 2009
  3. rufty_tufty_hoolythug
    Greybeard Guest
    I made my own set up years using the little plastic air flow taps for fish
    tanks, you can get them from any pet shop and are very cheap.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Sep 3, 2009
  4. Haven't you just said exactly the same as TOG? Why plagiarise him? Can
    you not think of anything to say yourself?
    Simon Atkinson, Sep 3, 2009
  5. rufty_tufty_hoolythug
    Greybeard Guest
    I have said completely different to TOG.
    My suggestion was instead of using clamps, to use valves.
    2 completely different ideas!
    Greybeard
  6. rufty_tufty_hoolythug
    Even copied his very words.
    Ace, Sep 3, 2009
  7. rufty_tufty_hoolythug
    No, you repeated his words as your own. Try re-reading your own post.
    Ace, Sep 3, 2009
  8. rufty_tufty_hoolythug
    Greybeard Guest
    I don't think I have.
    But then again, you mindless sheep all follow one another.
    Greybeard
  9. It's sad and pathetic to do that.
  10. You wrote exactly what TOG did, then to try and make it look like you
    were capable of thought added a sentence on the end. You're a forger.
  11. True. Forger.
  12. rufty_tufty_hoolythug
    Greybeard Guest
    It must be your foreign interpretation then.
    I'm very sure that "Tap", is not "Clamp"
    In case you are not familiar with Aquarium concepts, you can indeed get, as
    TOG has rightly said, although no mention of Pet Shop or aquaria, clamp type
    fittings.
    You can also get, and which IMHO would be a little easier to use, a proper
    bank of air flow taps, or valves if you so prefer. These are 2 very
    different ideas, but with the same outcome, cheap and effective.
    Greybeard
  13. rufty_tufty_hoolythug
    Greybeard Guest
    And you Sir are a complete Wanker.
    Perhaps you can show me where I wrote _exactly_ what TOG did?
  14. You only added that sentence on the end of the forgery post that you
    tried to pass off as your own when we all know TOG said exactly the same
    thing before you.
    Just to make it clear what you posted (as your won words) was:
    All stolen from TOG - word for word.
    Then you added this sentence to try and make us think you were posting
    something new:
    If you count the number of >'s you can see that you deliberately posted
    TOG's words as your own. We've caught you out forging posts as your own
    so admit it and move along. Forger.
  15. A pleasure.
    thing before you.
    Just to make it clear what you posted (as your own words) was:
    something new:
  16. rufty_tufty_hoolythug
    indeed.
    darsy, Sep 3, 2009
  17. Mexican.
  18. rufty_tufty_hoolythug
    Jim Guest
    Join the Campaign To Misuse Apostrophe's!
    Jim, Sep 3, 2009
  19. Possessive use on one, and missing letters on t'other.
    Next.
  20. There was a thread just a couple of days ago about Greybeard's lack of
    proper quoting. It is the same problem here in this thread. Outlook
    Express does not properly use > when replying to a Google Group post.
    Greybeard was advised to install OE-Quotefix to eliminate the problem.
    http://majorgeeks.com/OE-QuoteFix_d4029.html
    All other (competent) newsreaders quote Google Group posts properly. The
    fault is with Outlook Express.
    Beauregard T. Shagnasty, Sep 3, 2009
