Vacum Gague..
Discussion in 'UK Motorcycles' started by Ginge, Jul 11, 2004.
  1. Ginge
    Ginge Guest
    Anyone (lurkers included) in the midlands (Derby/Notts area ideally)
    got a 2 [1] or 4 dial vacum gague I could use to do a quick carb balance
    sometime this week?
    If I don'#t hear anything I'll probably go and buy one when the shops
    open on Monday.
    [1] A twin one would do the job as I can balance the carbs in pairs,
    then balance between pairs.
    Ginge, Jul 11, 2004
  2. Ginge
    Ginge says...
    Emailed
    Lozzo, Jul 11, 2004
  3. Ginge
    Ginge Guest
    And replied... (Isn't this an exciting read, everyone?)
    Ginge, Jul 11, 2004
  4. Ginge
    Ginge Guest
    <grin> I noticed that once I hit send, then realised I'd not had my
    first cuppa of the day so was typing on auto pilot.
    "That'll learn me"...
    Ginge, Jul 11, 2004
  5. Lozzo's is probably a four-gauge set. Balancing between pairs doesn't
    always work perfectly, as there's a surprising amount of interaction
    between all four carbs.
    The Older Gentleman, Jul 11, 2004
  6. Ginge wrote
    I've got one. A bit far away for you though innit?
    steve auvache, Jul 11, 2004
  7. Ginge
    Ginge Guest
    Well, I'd go back and check afterwards but the Kwak service manual even
    suggests between pairs, and there are 3 adjusting screws.
    Balance between 1&2
    Balance between 3&4
    Balance Pair 1&2 against 3&4
    I could get by without doing it but there's a moment of lag when
    initially snapping the throttle open, that annoys me so i'd rather sort
    it.
    Ginge, Jul 11, 2004
  8. Ginge
    Ginge Guest
    No. It's not even badly out, just not what I'd call spot on.
    Ginge, Jul 11, 2004
  9. Ginge
    Salad Dodger Guest
    Teaspoons.
    Carb balancing tools of the Gods.
    | ___ Salad Dodger
    |_\_____/_| ..66257../..15856.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:35 Pts: 705 Miles:2429
    Salad Dodger, Jul 11, 2004
  10. Ginge
    Porl Guest
    Probably the tool of choice for Mary Poppins.
    Porl, Jul 11, 2004
  11. Ginge
    Ginge Guest
    How does that work then?
    Ginge, Jul 11, 2004
  12. Ginge
    Ginge Guest
    Except this weekend I've already changed the following..
    Spark Plugs, air filter, oil filter, oil.
    The carbs were last balanced over 8,000 miles ago, I didn't do them at
    the minor service as all felt fine then. The bike felt the same way
    last time they needed doing (when they were just a tiny bit out) the
    acceleration whilst not bad just isn't as crisp.
    Anyhow, it'll get done some time this week one way or another..
    Ginge, Jul 11, 2004
  13. You're not disagreeing at all - you're describing the extra hassle
    rather better than I did. I didn't mean that using a twin-gauge set is
    impossible; just that the job is much harder than with a four-gauge set.
  14. File the ends of the handles flat, and then bend them, and you can get a
    teaspoon into inaccessible areas, like between the individual carbs.
    Very handy. Make sure you use stainless teaspoons, though, because they
    won't strike a spark. Trust me - you don't want sparks near carbs that
    are filled with petrol.
  15. That's interesting but not unusual these days - one carb is often used
    as a datum.
    It's still a damn sight easier with a proper set of four gauges, mind.
    See my reply to Simes.
  16. Ginge
    Eiron Guest
    Ginge wrote:
    That sounds like a mixture problem, not balance.
    Have you been Dynojetted?
    Got anything non-standard?
    Eiron, Jul 11, 2004
  17. I dunno. I've often wondered that.
    The carbs on the 400 Four go out of synch quite quickly. The carbs on my
    old Kawasaki GT750, which I sold to Eddie and he sold on to Statto,
    never went out of balance while I had the bike, in God-knows-how-many
    miles. I doubt they've ever been checked since.
    I never even bothered checking the carbs on my old 900 Diversion because
    it just sounded and felt and ran sweetly and if it wasn't misbheaving, I
    didn't see the need to fiddle with it.
    I've never checked the Trophy, either, for the same reason.
  18. It does, rather.
  19. Ginge
    Gyp Guest
    I've got a 4 set but I guess I'm not entirely local
    Shame you didn't ask on Friday as SWMBO is visiting her folks & could
    have brought the kit with her
    Gyp, Jul 11, 2004
  20. Ginge
    The Guzzi needs doing because it /does/ vibrate like a bastard. More so
    than normal.
    ....and since cleaning the breather box and letting the bike fall over
    (arse) a pack/herd/anglican of mice have taken up residence somewhere
    under the tank; in the engine area. When warm.
    I'm rather hoping this isn't related to the recent "continue to thrash
    the **** out of it whilst it's emptying the sump via the breather"
    episode.
    sweller, Jul 11, 2004
Similar Threads
Loading...
