V45 Magna Eletronic Ignition location
Discussion in 'Motorbike Technical Discussion' started by Vic, Aug 20, 2004.
  1. Vic
    Vic Guest
    Just bought the V45 Magna, ran well for a week, then started to
    sputter, RPM ran from 5000-7000-5000 loosing a little power till i'm
    up to speed. Honda of anderson SC. wouldn't touch it. They sent me to
    a Bike-JunkYard to get worked on, no-can-do for a week, too busy...
    would like to change electronic ignition myself so that I could get to
    ride quicker. Can anyone help?
    Vic
    Vic, Aug 20, 2004
  2. Vic
    Mark Olson Guest
    Why do you think it is an ignition problem? What tests have you
    performed that would confirm or rule out ignition problems as a
    possible cause of the symptoms you are experiencing?
    I'm not saying it _isn't_ an ignition problem, but there are things
    you can test and inspect that will lead you toward or away from ignition
    trouble as the diagnosis.
    I would diagnose the problem *before* I went shopping for parts,
    doing it in the wrong order wastes too much time, and is too expensive.
    Visit http://www.sabmag.org, they can help you if anyone can.
    Mark Olson, Aug 20, 2004
  3. Vic
    Charlie Gary Guest
    Mark Olson wrote:
    It's also helpful if the OP mentions what year model it is.
    Charlie Gary, Aug 20, 2004
