V12 Kawasaki
Discussion in 'UK Motorcycles' started by Muck, Jun 29, 2005.
  1. Muck
    Muck, Jun 29, 2005
  2. <cue WUN sobbing>
    I liked this though:
    "[fuel tank]Capacity is still a generous eight gallons, which is just as
    well because consumption was initially around 8 mpg...."
    Makes my bandit seem frugal!
    Dnc
    ZZR1100 - tagline being developed
    B1200 - +30bhp ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, Jun 29, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Doesnotcompute
    Seen it. Bloke's a nutter. I'm glad he exists though...
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jun 29, 2005
  4. Muck
    Salad Dodger Guest
    Is that all? Pah.
    Salad Dodger, Jun 29, 2005
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    It's actually lighter than a stock ZN1300 Voyager.
    Which is a bit of a worry, frankly.
  6. Muck
    Crumbs, you must have a lot of bling on that. :)
    It is indeed. How much exactly does your Voyager weigh again?
    Muck, Jun 29, 2005
  7. Muck
    Ok, so how much does yours weigh then big boy...
    Muck, Jun 29, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    382Kg, dry.
  9. Muck
    Salad Dodger Guest
    In theory: 408kg.
    Mine's had some bits bolted on, though.
    Prolly another 10kg, at a guess.
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    TOG's fond of pointing out that the engine weighs the same as an X7. A
    *whole* X7...
  11. Muck
    Bear says...
    The 9R C2 is 186kg dry IIRC, about the same as a GPZ500S.
    Lozzo, Jun 29, 2005
  12. Muck
    How are you these days?
    platypus, Jun 29, 2005
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    <trembly voice>
    Hanging[1] in there, thank you for asking. Still not mad, apparently.
    Still not fit for work, for another week.
    </tv>
    [1] Not by the neck. Yet.
  14. Muck
    JB Guest
    *Christ*!
    <stunned>
    JB
    JB, Jun 29, 2005
  15. Muck
    Bear says...
    I knew, you didn't.
    About that, yep. The GPZ is actually 179kg according to the green men.
    Lozzo, Jun 29, 2005
  16. Muck
    Cheer up, you miserable bugger.
    The way things are at work atm, I'd be so tempted to have a psychological
    episode. No-one would believe me, though.
    platypus, Jun 30, 2005
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    <slaps forehead>
    I'm cured! It's a miracle!
    Err...
    Wicked Uncle Nigel, Jun 30, 2005
  18. Muck
    Ben Blaney Guest
    Get a second opinion. Show them your garage, if necessary.
    Ben Blaney, Jun 30, 2005
  19. Muck
    Bear says...
    My old handbook said 186kg for my C2, but you're right that the quotes
    seem to be all over the place.
    Lozzo, Jun 30, 2005
  20. Muck
    Blimey. Nothing that can't be fixed with my new angle grinder. :) I bet
    it weighs more than all my bikes dry weights put together when it has
    fuel and oil in it.
    Muck, Jun 30, 2005
