V-Twin Cylinder floods frequently
Discussion in 'Motorcycle Technical Discussion' started by pinkpanther, Jan 30, 2006.
  1. pinkpanther
    pinkpanther Guest
    I have an '84 Yamaha XV-1000 that the rear cylinder floods frequently
    on. The bike has an aftermarket manifold that is set-up for only a
    single carburetor. So it is obviously not that one carb. is running
    richer than the other. The rear plug shows signs that it is fuel
    fouled; however, I switched the plugs (front to back) and still the
    rear cylinder floods. The plug that was in the rear (now in front)
    looks okay and the other plug looks fuel fouled. So the problem stays
    with the cylinder.
    I am new to cycle repair and am unsure as to what to check next. Any
    suggestions would be appreciated.
    Thanks,
    Larry
  2. pinkpanther
    Alfred J. Guest
    What kind of carburetor is it, a 1-barrel or a 2-barrel carb? A
    2-barrel carb might have
    2 idle jets and 2 main jets and one main jet might have fallen out.
    Or, is the spark plug *really* gas fouled, or is it oil on the plug?
    And oil-fouled plug would obviously be oily, a gas-fouled plug would be
    wet and smell like---doh!---gasoline.
    Then there is the possibility that your problem is a bad spark plug
    wire. Some ignition system designs are simple, one coil fires two spark
    plugs at the same time and it's possible to switch plug wires to see if
    the symptom moves from one cylinder to the other.
    And then there is the old trick of raising the voltage at which a spark
    plug fires by holding the spark plug cap about 1/4 of an inch away from
    the end of the spark plug while the engine is running to see if the
    plug starts firing. If it does, that suggests something wrong with the
    spark coil triggering mechanism or the ignition control box or shorted
    high tension windings inside the coil itself.
    Then again, maybe you just have a bad 12 volt connection where the coil
    gets its power from the motorbike's wire harness.
    Alfred J., Jan 30, 2006
  3. pinkpanther
    pinkpanther Guest
    The carb is a single barrel.
    The plug looks fuel fouled. The residue is not oily and smells like
    gas.
    Thanks for the other tips. I'll look into them.
    Larry
  4. pinkpanther
    Alfred J. Guest
    How's the compression on the cylinder that fouls the plug? Are both
    valves set right?
    Alfred J., Jan 31, 2006
  5. pinkpanther
    alan&alon Guest
    sounds to me like its a imbalance with the fuel atomising with the single
    carb kit. not sure of the cure other then going back to the duel carb setup.
    i have seen other engines like this i have put a stainless screen in the
    cylinders intake thats running rich and it did cure all of them but these
    were small engines kawasaki mule engines to be excact. but i dont know how
    you would do that to yours. i would try to get the stock setup back
    alan&alon, Feb 11, 2006
  6. pinkpanther
    pinkpanther Guest
    First off I found out that the replacement filter I used was gas
    soluble even though you are suppose to oil it. This was causing some
    major problems.
    The trick for increasing the spark really worked well. I re-gapped the
    plugs. This seemed to help a lot.
    I hosed down the carb. with spay cleaner this seemed to help a lot too.
    pinkpanther, Feb 14, 2006
