Using oversized piston rings
Discussion in 'Motorcycle Technical Discussion' started by Paul Barrett, Nov 8, 2005.
  1. Paul Barrett
    P.J. Berg Guest
    Far from it, two questions from two people, two answers...
    J.
    P.J. Berg, Nov 10, 2005
  2. Paul Barrett
    Matt Guest
    Obviously it would be suboptimal according to manufacturers' standards.
    I don't see that anybody has offered standard knowledge or experience
    with the long-term effects, so I offer the partial results of a thought
    experiment.
    The rings would bear unevenly on the insides of the cylinders, and with
    a greater-than-standard total force. There would be a couple of high
    points on the circumference of each ring. I would expect those high
    points to fall into troughs that would eventually be worn into the
    cylinder walls as the rings stop rotating in the piston grooves. Each
    cylinder would develop an oblong cross section. I would expect problems
    with ring and cylinder lubrication after the rings stop rotating.
    Matt, Nov 10, 2005
  3. Paul Barrett
    skimmer Guest
    Be careful about how much you play with your brain. I've heard you'll
    go blind ;-)
    And some rings don't rotate at all. Two-stroke rings have pins to
    prevent the ends from rotating out into the exhaust port and snagging.
    Apparently all of this commotion about fitting oversized rings---which
    I'd never heard of before---is to optimize the ring gap to reduce
    compression leaks to the smallest possible amount.
    But ring manufacturers advise engine rebuilders to stagger the end gaps
    120 degrees apart on a 3-ring piston to provide a tortuous path for
    what minuscule amount of hot gas does slip through the tiny end gap.
    With three gaps, the gasses will have to go 2/3rds of the way around
    the piston to get to the crankcase...
    And then consider the time aspect when an engine is operating at, say,
    12K RPM.
    It completes 200 revolutions in a single second. A complete revolution
    takes place in 0.005 seconds. But the amount of time that a piston ring
    is "seeing" a large pressure, starting at around 900 PSI and declining
    to maybe 20 psi is about 90 to 120 degrees of revolution. And even this
    event occurs only once every *fourth* stroke.
    I think we are talking about how much hot gas can leak past a ring gap
    in a bit over a thousandth of a second, folks. I wonder how much of
    this precious combustion gas we can afford to lose?
    Are we gonna run out of combustion gasses and have to go to electric
    motors because of the horrendous losses? Will we have to go to fuel
    cells or a hydrogen technology just because of end gap blowby?
    It staggers the imagination! And now my vision's getting blurry! I
    think I'm going blind, Matt!
    Maybe this whole concept is like penis enlargement. Obviously,
    everybody in the world (except me) needs a bigger penis.
    The performance enthusiast's penis has wheels attached. This dedicated
    amateur performance tuner decides that he needs a better diagnostic
    tool than a compression tester, so he runs out and buys a *leak down
    tester* and he pressures his cylinder and watches to see how much
    static leak down he's getting.
    Once he sees that he's losing his "purity of essence" through the ring
    end gaps, he tears the engine down and installs over-sized rings so he
    can reduce his end gap and save the essential combustion gasses.
    I'll bet the static leak down fan is thrilled to death by how "tight"
    his engine is!
    But you don't make any power when the piston isn't moving, so the
    tightest engine in the world is about as useless as a nun on Thursday.
    skimmer, Nov 10, 2005
  4. I did it because I got sold the wrong size ring and couldn't be arsed to
    go back, get them changed, etc etc.
    And I was a teenager, like I said.
    Anyway, it worked for me and worked for the other poster here who's done
    it, so end of story, really.
    The Older Gentleman, Nov 10, 2005
  5. Paul Barrett
    les Guest
    The OP was talking about oversized rings on standard pistons, same as "R.
    Pierce Butler". This could be done by filing the ends to get the correct
    gap. I wouldn't do it, but I won't say it wouldn't work either.
    Les
    les, Nov 11, 2005
  6. 0.0196 rounds off to 0.020 in. Difference between a 0.5 mm over and
    0.03 inch over is only 0.01 inch so it's not that much. Difference in
    radius for 0.03 in. over is only 0.094 in. For say a 4 inch dia.
    piston, that is only 2% change, so I doubt spring tension was an issue.
    I somehow feel something else was going on. Did V-8 installer ensure he
    had correct ring gap after filing and correct ring fit in groove, same
    ring width as original?
    High Plains Thumper, Nov 11, 2005
  7. Paul Barrett
    Peter V Guest
    Just from an engineering point of view, a .5 mm (about .020) oversize
    piston ring is ground "round" at that diameter.
    If it is used in a smaller bore (on a smaller piston), it is no longer
    circular even though you've ground down the ends to have the correct end
    gap.
    I know it's not much out of circularity, but the "hoop stress" that a
    piston ring imparts is a function of how circular, and consequently, how
    even is that stress distributed.
    But, if someone has done it and it has worked... hey, what do I know?
    CP
    Peter V, Nov 13, 2005
  8. Paul Barrett
    Matt Guest
    Nobody on this thread has offered experience regarding the long-term
    effects of using oversize rings.
    Matt, Nov 14, 2005
  9. Paul Barrett
    Pale Fire Guest
    Somebody who would use oversized rings to reduce the leakage past the
    end gaps probably wouldn't care about the long-term effects, they'd be
    chasing the immediate mouse milk.
    You have to milk a lot of mice to get a drop of milk...
    Pale Fire, Nov 14, 2005
  10. Who cares?
    The Older Gentleman, Nov 14, 2005
  11. That is quite true. Most people do things by the book.
    My father had a strange air cooled engine that he needed rings for. There
    were no piston rings available at the time so he grabbed a book of the
    various automotive piston rings available and found that he could use piston
    rings from a Packard. They fit so he used them.
    pierce
    R. Pierce Butler, Nov 15, 2005
  12. Paul Barrett
    Matt Guest
    probably not anybody who expects to be kicking the bucket soon
    Matt, Nov 15, 2005
  13. You're not very bright, really, are you?
    The Older Gentleman, Nov 15, 2005
  14. Paul Barrett
    Matt Guest
    Hey, did you get an insurance payment for that messed-up CB175 that got
    stolen?
    Matt, Nov 15, 2005
  15. What messed-up CB175?
    If you mean my bloody nice, clean, sparkling and sweet-running bike,
    then yes. More than I'd paid for it, too :))
  16. Paul Barrett
    Matt Guest
    I mean the one that had wrong-size piston rings.
    Matt, Nov 15, 2005
  17. <snip>
    <loses patience>
    Do **** off, you pathetic, inadequate, unprincipled, nasty, stupid,
    vindictive, childish little by-product of an inbred village idiot's
    wank.
  18. Paul Barrett
    Matt Guest
    that's what you believe you are
    Matt, Nov 15, 2005
  19. Oh, shit! I didn't realise that TOG's 175s had a habit of getting
    stolen... Oh well, it's in the hands of the insurers now.
    Why didn't you turn up at the pub Friday night, anyway? You had
    enough instruction on ways to get home!
    GSX600F, RG250WD, DT175MX-MIA "You Porsche. Me pass!" DoD #484 JKLO#003, 005
    Dr Ivan D. Reid, Nov 15, 2005
  20. Got the wrong date.....
    The Older Gentleman, Nov 16, 2005
