Using 12v lights on a 6v system
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Apr 2, 2007.
  1. Early four-stroke Suzuki electrics were, indeed, dreadful.
    A very common mod on this side of the pond, too.
    Twin-choke carbs. Common in the car world. Kawasaki used the same system
    on the early Z1300s (only the bike had three of them, of course).
    To be fair, this could be said of most (but certainly not all) Jap
    bikes.
    The Older Gentleman, Apr 5, 2007
  2. *Sensible* engineering, that's what. It's someone saying: "Well, we know
    we've built a decent system, but batteries do die, and people neglect
    them, so just in case, let's have a system that can start the bike with
    a flat battery."
    MZ - some of the most sensibly-designed bikes ever made, no matter that
    they were Commie - had exactly the same facility.
    You can't call it crap engineering. It's *good* engineering.
  3. Masospaghetti
    Gene Cash Guest
    Indeed. I wish I had that in current bikes. The battery in my SV-650 is
    too tucked away to use regular car jumper cables, and I got stuck at
    work once because of that. So I've had to add the feature myself.
    The reason the battery was dead is that goddamn "park" position at the
    wrong goddamn position on the ignition switch.
    A moment's inattention and you switch one position too far, and later
    you come out of work and see your taillight dimly lit, and you know
    you're fucked.
    Why the hell couldn't they put the position somewhere else, like the
    other end of the arc?
    I've disabled it on ALL my bikes. What a pain in the ass.
    Is this a US-only horror or are people all across the world cursed with
    that crap?
    -gc
    Gene Cash, Apr 5, 2007
  4. No. we get it in the UK, too, and I bet everyone's managed to leave
    their parking lights on at least once.
    What I can't understand is why old B12, Green Pea, and whatever he
    calls himself now should yammer about it: I mean, it was on a Honda
    half a century ago. There were some far stranger "engineering
    solutions" around at that time.
    MZs, incidentally, had a special detent position on the ignition
    switch for "flat battery start". You turned the key one click anti-
    clockwise (IIRC), and kicked it, and it would start. Lovely.
    chateau.murray, Apr 5, 2007
  5. Masospaghetti
    Gene Cash Guest
    I kicked my SV a LOT when the battery got killed, and it never started.
    Oh, *that* kind of kick! :)
    Seriously, why did it need a particular position on the key? What am I
    missing? I don't understand.
    I actually enjoyed my RZ-350, it rarely never took more than 3 kicks,
    and usually started on the first, if it wasn't too cold.
    -gc
    Gene Cash, Apr 6, 2007
  6. No idea. It just had one.....
    The Older Gentleman, Apr 6, 2007
  7. Masospaghetti
    Albrecht Guest
    Disconnecting the alternator from the battery probably
    unclamped its output voltage from 11 volts or so battery
    and allowed more voltage to get to the ignition system.
    Did the owner's manual warn the rider to immediately
    switch back to the normal ON position after the engine
    started?
    Or did MZ rely on the lighting system to keep voltage
    down to a manageable level?
    Albrecht, Apr 6, 2007
  8. Masospaghetti
    James Clark Guest
    If they went to trouble of adding a switch position, it's possible that they added a capacitor to
    substitute for the battery. My guess is the extra position diverts all alternator output to the
    ignition system - no lights, no battery.
    James Clark, Apr 7, 2007
