Usenet at work
Discussion in 'UK Motorcycles' started by TimP, Jun 9, 2004.
  1. TimP
    TimP Guest
    Having initially claimed that I was likely to get viruses onto the work
    network by using newsgroups, the snivelling git that organises our computers
    at work has told me to stop using the newsreader because it's against
    company policy to use computers for non-work stuff.
    I've decided to ignore him as basically everyone uses web-based email (incl
    both my bosses), but is NNTP traffic likely to be logged like email and
    internet traffic? It would be nice to ignore him with impunity.
    Tim
    TimP, Jun 9, 2004
  2. TimP
    Dan White Guest
    Just use Google Groups and post from there.
    Then when you leave, call him a twat.
    Dan White, Jun 9, 2004
  3. TimP
    Slider Guest
    Depends on how your machine reaches the Internet. It's very unlikely that
    they will have more information logged than the general info saying you were
    connected to NNTP server z between times x and y. The chances of your
    network's NAT or proxy actually interrogating the NNTP packets is highly
    unlikely IMHO, so at least they won't tell which binary groups you spend all
    day salivating over. :)
    Slider, Jun 9, 2004
  4. TimP
    dwb Guest
    Not the point - if your company policy is "no work related stuff" just
    because every one else does it won't
    help if they take you to task for it - especially if you signed something
    saying you wouldn't. [1]
    As has been mentioned elsewhere, occasionally it's things like this that
    might be used if they can't get rid of you any other way...
    [1] my company is the same, everyone does it - sometimes even for work
    reasons - but I know full well that if I should be asked
    about it, there isn't an awful lot I can say... " I was waiting for a query
    to finish running"
    dwb, Jun 9, 2004
  5. TimP
    TimP says...
    Ask Jeremy
    Lozzo, Jun 9, 2004
  6. TimP
    Jeremy Guest
    Love to help but rather busy trying to work out if there is a way you
    can reboot a windows PC by some combination of keyboard button presses.
    jeremy
    ['75 RD250A ] | ['02 Fazer 600 in blue]
    jeremy at hireserve dot com
    Jeremy, Jun 9, 2004
  7. TimP
    ctrl+alt+del
    s
    r (for restart)
    s (for shutdown)
    l (for logoff)
    return
    sweller, Jun 9, 2004
  8. TimP
    ctrl-alt-del
    right arrow
    right arrow
    return
    up arrow
    up arrow
    up arrow
    up arrow
    up arrow
    down arrow
    down arrow
    return
    (if not NT/2K/XP, only hit the down arrow once)
    Think about it.
    ogden, Jun 9, 2004
  9. TimP
    If it's NT/2K/XP, insert two right arrow keypresses and a return here.
    ogden, Jun 9, 2004
  10. TimP
    But my method works on W2K, is easier and more certain. Which in the
    circumstances is a good thing.
  11. TimP
    Ignore what I posted, it was bollocks.
    For a change.
    ogden, Jun 9, 2004
  12. TimP
    entwisi Guest
    Or setup a VNC server on your home PC and access it from work and use your
    newsreader on your home PC.(Broadband dependant)
    entwisi, Jun 9, 2004
  13. TimP
    nonsense.
    windows-key
    up arrow
    return
    alt-R
    return
    darsy, Jun 10, 2004
  14. TimP
    actually, alt-R only works for pre-XP Windows; for XP, substitute an
    up arrow, a down arrow or nothing, depending on which way the machine
    was shut down the last time.
    For 2003 Server, there's probably more fannying about as you need to
    specify the reason for the reboot. Still all keyboard-achievable
    though.
    darsy, Jun 10, 2004
  15. TimP wrote:
    Make sure you subscribe to a suitable newgroup that is work related...
    eric the brave, Jun 10, 2004
  16. TimP
    dwb Guest
    That is such a 'useful' feature - I wonder if anyone actually does put in a
    valid reason.
    I have rather a lot of "sdsdfs" in my reboot logs :-|
    dwb, Jun 10, 2004
  17. TimP
    well, I rebooted a 2003 box twice yesterday, and put in the correct
    reason (software installation[1]) both times.
    I have a minion to look at logs.
    [1] note to unix-weenies: I could have done it without a reboot, but
    I'm lazy and it's a dev box.
    darsy, Jun 10, 2004
  18. TimP
    Very Unixy.
    Much like a Solaris box - it expects you to use the shutdown command,
    give a time delay, a reason, etc. Or you can just type 'init 6' and
    watch it all happen straight away.
    Pointless.
    ogden, Jun 10, 2004
  19. TimP
    Logorrhea Guest
    Ah, this just *has* to be the happiest misprint of the morning!
    Logorrhea, Jun 10, 2004
  20. TimP
    Ginge Guest
    We use it on one of our shared production machines (although most are
    still W2K), because there are about 20 techies that may be involved in
    supporting it, and it's nice to know why something was rebooted if
    you're picking up work from somebody else.
    Ginge, Jun 10, 2004
