Useful very dead battery trick
Discussion in 'UK Motorcycles' started by TMack, Jul 28, 2009.
  1. TMack
    TMack Guest
    Went to start the Ducati this morning - zilch, nada, nothing doing. I
    guessed that I might have inadvertently turned to the "park" position last
    time I removed the key and the lights had drained the battery. A stupid
    fucking design fault that has tripped me up sooner or later on every bike
    that I've owned with this feature. Usually I notice when I am walking away
    but not this time apparently. Anyway - no problem I thought, just hook it
    up to the optimate via the lead already attached to the battery and go out
    on the v-strom instead.
    Optimate says "no". There then follows 15 minutes of fairing wrestling to
    get the battery out. The oximiser in my spare room then also says "no", car
    battery charger also says "no". I check the voltage across the battery
    terminals which turns out to be all of 0.3v. Not good. Suddenly I have a
    brainwave - I dig out an old spare battery that still has a reasonable state
    of charge. I connect this in parallel with the fucked Ducati battery and
    then apply the oximiser. Left it for 10 minutes or so then removed the old
    spare battery and the Duc battery is now charging successfully. Result!
    TMack, Jul 28, 2009
  2. TMack
    Dave Emerson Guest
    I've used this trick ever since the chargers got too clever for their own
    good.
    In the old days it was sufficient to hook a bulb in parallel with the "dead"
    battery, so the charger would see some load and not just an open circuit.
    Dave Emerson, Jul 28, 2009
  3. TMack
    Catman Guest
    How is this a design fault?
    www.cuore-sportivo.co.uk
    Catman, Jul 28, 2009
  4. Of course, if you had a sensible traditional trickle charger without all
    the eeelecbollocks in it, you wouldn't have a problem charging an
    utterly flat one up.
    Grimly Curmudgeon, Jul 28, 2009
  5. What else would it be? Somebody designed it, it didn't fall off a tree,
    and it's prone to being left on accidentally - faulty design. Nul
    points.
  6. TMack
    Catman Guest
    Hmm, in interesting interpretation.
    You don't think there's an element of user error involved, at all?
  7. IMO It is the job of a designer to make things not only work, but,
    work in such a way that success is ensured.
    Remember floppy discs? Remember how they only go into the drive the
    correct way? That's a 'poke yoke' design - it has been designed in a
    way that is 'mistake proof'. CD's and DVD's are a step back in this
    regard, as they can be inserted incorrectly.
    Doesnotcompute, Jul 28, 2009
  8. TMack
    Eiron Guest
    In the old days it was sufficient to connect a battery charger to the battery.
    You must be referring to the good recent days.
    Eiron, Jul 28, 2009
  9. TMack
    Catman Guest
    That would be sensible, indeed.
    Cars have an audio warning on *parking* lights? Must be really annoying
    for anyone you park next to.
  10. TMack
    Catman Guest
    Would you like to bet on that? I mean *really*?
    Indeed. Self correcting though, as it won't function, of course, and
    fails safe.
  11. TMack
    TMack Guest
    We shall see - it hadn't been like that for long. Currently (pun intended)
    its up to yellow on the oximiser so with a bit of luck it will be green
    tomorrow.
    TMack, Jul 28, 2009
  12. TMack
    TMack Guest
    Because there is very little movement between the "lock" position and the
    "park" position, making it very easy to leave parking lights on
    accidentally. My v-strom is similar as are many bikes. If the "park
    position required the key to be moved a further 90 degrees, or better still
    if there was a secondary switch in addition to the "park" position, then
    much grief could be avoided.
    TMack, Jul 28, 2009
  13. TMack
    TMack Guest
    I didn't think it would be an original idea, I was just pleased to have
    worked it out for myself.
    TMack, Jul 28, 2009
  14. TMack
    Catman Guest
    And this was the same on all your other bikes? Bad luck, old chap. The
    Sprint needs (IIRC) about 50 degs.
  15. TMack
    Catman Guest
    I really doubt that leaving the parking lights on will fry the ECU.
    Leaving the ignition on, OTOH.
  16. TMack
    All depends on how you connect up the battery when jump starting the
    bike the next morning... or so I'm reliably informed
    Lozzo, Jul 28, 2009
  17. TMack
    TMack Guest
    Thus demonstrating the difference between good and faulty design...
    TMack, Jul 28, 2009
  18. TMack
    Catman Guest
    Oh *yes*. Forgot that bit.
    Catman, Jul 29, 2009
  19. TMack
    TMack Guest
    Green light!
    TMack, Jul 30, 2009
  20. TMack
    Simon Wilson Guest
    *phew*
    I was on the edge of my seat.
    Simon Wilson, Jul 30, 2009
