Urethane
Discussion in 'Motorcycle Technical Discussion' started by Torgeir Haukenes, Feb 21, 2005.
  1. From what I`ve been told its possible to use urethane instead of
    nitrile-rubber for carburettor intake manifolds. The gains are
    longevity, strength and very good resistance to HC`s.
    With this in mind I contacted a local specialist in urethane molding
    because the original parts just don`t last.
    Strength and HC tolerance would be no problem he said, but temperature
    might be, as urethane softens when heated above 90 degC (200F +/-).
    That was news to me, so I thought it worthwhile to post about it here.
    What temperature will the intake manifold of a 2-stroke 500cc liquid
    cooled engine typically see? My guess is that it will benefit from the
    cooling effect of the air/gas mixture being sucked through.
    But to what extent? Has anyone done any empirical tests on this?
    How about other types of urethane, i.e. duo/poly?
    TH
    `96 ZX6R
    `86 Maico 500
  2. Torgeir Haukenes
    Mark Olson Guest
    Despite the widespread perception that factory engineers are ignorant
    and/or overly controlled by the bean-counters, the OEM manifolds are
    probably made out of the best possible material without resorting to
    extremely expensive and hard to work with materials.
    Are you actually experiencing a performance problem with the stock
    manifold? Manifolds for inline-four air cooled bikes can routinely
    last for 20 seasons of riding before needing replacement due to age.
    I imagine that a liquid-cooled 2-stroke intake would be a relatively
    benign environment compared to an air-cooled 4-stroke.
    Mark Olson, Feb 21, 2005
  3. Thanks for your input.
    Sadly, there is a performance problem with the stock part. It cracks
    from vibration and lack of strength. Then air is sucked in through the
    cracks, leaning out the mixture and causing the rpm`s to increase.
    This is not pleasant on a 500 smoker... Can ruin the engine too. I
    replaced the part with a new one in september 2002, yet within less
    than a year the problem came back. I have seen it mentioned online in
    Maico-forums too, so I know its not just my bike that`s affected.
    As to factory engineers; when they get so much right, ignorance is not
    what I`d think of just because some minor part fails. Yet budgets need
    to balance and compromises are made.
    Which in turn fuels the aftermarket industry, and more importantly,
    inspires tinkering owners to try their hands on DIY improvements.
    I wouldn`t miss it for the world!
    TH
    `96 ZX6R
    `86 Maico 500
  4. Torgeir Haukenes
    Mark Olson Guest
    This sounds like they are asking the manifold to support the carb in a way
    that puts too much stress on the manifold. Perhaps adding a reinforcing
    brace to the carburetor would be a reasonable way to avoid overstressing
    the manifold.
  5. While it's true that the rubber boot will be cooled by evaporation of
    gasoline during operation, that effect will cease when you park the
    motorbike, and the rubber boot will then be baked by the cylinder block
    which will probably be about 180 to 212 degrees F...
    Maybe higher, I remember that owners of the original Kawasaki 900cc
    Ninjas were upset by seeing water temperatures that they thought were
    up around 275 degrees F...
    But, rather than have expen$ive rubber boots custom made, have you
    considered getting some large diameter o-rings that will fit in the
    grooves on the carburetor spigots and just use some short pieces of
    automotive radiator hose clamped over the o-rings?
    I don't mean the corrugated type of hose which is meant to bend around
    corners. I'm referring to that other type of smooth rubber/fabric
    hose...
    krusty kritter, Feb 21, 2005
  6. Torgeir Haukenes
    John Johnson Guest
    Say more about these cracks: are they circumferential or axial? Do they
    appear in a particular place each time, or are they evenly distributed
    about the boot?
    Knowing more about your application would also help: what bike is
    it-that Maico? Have you modified the intake tract? Is this a known
    problem with these bikes?
    It's possible that there's something else going on here that's causing
    the boots to crack, other than simply bad materials choice or part
    design. Knowing more about the circumstances could allow us to help you
    more effectively.
    Even if the OEM parts aren't up to it, that doesn't mean that the
    material itself is the problem: it's possible that a heavier boot, or a
    boot reinforced with the proper materials, would do the job. If you're
    already talking to someone who does moldings, bring them one of your
    failed parts and see if they have some ideas about how to avoid this
    problem in the future.
    It's also possible that you can find a carb boot from some other bike
    that fits and is more robust. This option will require a lot of work,
    tracking down similar objects and comparing them to your own.
    John Johnson, Feb 21, 2005
  7. Well... no references to R. Wagner??? Oh well... Anyhow, I did
    consider the radiator hose solution, and what backed me off was the
    lack of room between carb and reed cage - not to mention that I`d need
    to customize a fixing point for said radiator hose on the engine. The
    original part is bonded to an aluminium plate which holds the mounting
    screws, and furthermore it continues past that to form a directional
    tract for the gas flow towards the reed cage. So, I`d have to have a
    piece of aluminium machined to perform that role before a rad-hose
    even had a hope to enter the equation.
    The way I see it I`m left with two evils. Go with the flow and buy
    OEM, or go against the grain and make the part out of urethane or some
    other material.
    Sure, I`ve got the time to experiment; this bike is a pet peeve of
    mine. It`ll follow me to my grave. But that`s not to say I`m not in a
    hurry. Got any insight into the various kinds of urethane and their
    properties? I sure would appreciate it.
    TH
    `96 ZX6R
    `86 Maico 500
  8. The cracks are circumferential, not evenly distributed, they do occur
    in a haphazard way throuhgout the length of the manifold.
    Known prob, yes, as far as it has been mentioned in online forums.
    The bike is a 1986 model watercooled 500 MX`er. That`s M-Star in
    America - what`s in a name???
    Can`t say much more than I already did. I know not to overdo
    tightening the clamps... The engine vibrates, but at a steady rate -
    like big smokers do.
    I did. Suggested solution was to use urethane. The only "if" was
    temperature.
    Been there....tried that. KTM was a brand I figured had lots of parts
    in common with my Maico, but it seems parts for those old katooms is
    also hard to find.
    TH
    `96 ZX6R
    `86 Maico 500
  9. But then I`d have to buy another frail OEM part. Not to mention that a
    brace of some kind most likely would lock the carb solidly in place,
    yielding ample room for vibrations to cause fuel-frothing and who
    knows what. In short, I think that`d be an ounce of cure, not a pound
    of prevention. If I could I`d use fibre to reinforce the original
    design, but unfortunately that is not an option. I really hope
    urethane is.
    TH
    `96 ZX6R
    `86 Maico 500
  10. Torgeir Haukenes
    Paul Cassel Guest
    I'd try reinforcing the entire intake manifold with duct tape. That may
    sound like a joke to some, but I think it'll work fine & is surely worth
    a try. Duct tape is for *ducts*. I'd try it with two wraps around a
    currently cracked manifold to see what sort of service it gives.
    -paul
    Paul Cassel, Feb 21, 2005
  11. Well, thanks, need I say that I tried that? No arrogance intended, but
    I`m at my wits end and close to desperation. Besides, chewing gum and
    steeeel wire is a "fix" along the same lines. Grumpy? Oh yes, I`m on
    my last cigar! Wanna quit before I turn 40.
    TH
    `96 ZX6R
    `86 Maico500
  12. Torgeir Haukenes
    John Johnson Guest
    I don't know this bike so well. Are the carbs supported entirely by the
    carb boots? If so, removing the weight could make your carb rubbers last
    longer. I know you don't want to introduce vibrations to the carbs, but
    conceivably one could construct a support that is itself isolated from
    the vibrations of the engine.
    John Johnson, Feb 22, 2005
  13. Torgeir Haukenes
    bob prohaska Guest
    The notion of using the original manifold as a "mold" to which stronger
    materials can be applied might have merit. Duct tape and the stuff used
    for dipping tools handles won't be close to sufficiently heat resistant,
    but there might be other alternatives.
    One common high-temp rubber is Viton; don't know if it's available in a
    form usable for this purpose, but it takes 100 C with no problem and
    will survive 200 C for brief periods. If it's available as a latex one
    could use simply soak reinforcing fabric in the latex and wind it on
    the manifold.
    bob prohaska
    bob prohaska, Feb 22, 2005
  14. Torgeir Haukenes
    Mark Olson Guest
    The Viton info page at http://www.dupont-dow.com/Products/Viton/auto.asp
    says:
    "Application Range -40C to 225C with intermittent exposure to 285C"
    I think it might be a pretty good material for this purpose, but getting
    a single part made with Viton would be prohibitively expensive.
    Mark Olson, Feb 22, 2005
  15. stuff used for dipping tools handles won't be close to >sufficiently
    heat resistant, but there might be other alternatives.
    We made extensive use of RTV silicon rubber on the Apollo command and
    service modules...
    The red silicone RTV rubber is very heat resistant, but has low
    mechanical strength. Red RTV is commonly available in auto parts stores
    and I see people misusing it for gaskets to hold back oil leaks all the
    time...
    I got ahold of a tube of the white silicone RTV rubber when I worked on
    Apollo and used it to encapsulate the coils inside the lighting and
    ignition energy transfer magneto on my dirt bike over getting flooded
    out on a very wet day motocrossing. Later on, I wanted to disassemble
    the magneto and add another ignition primary coil in parallel to the
    first to get a really hot spark. I spent all day picking that white RTV
    off the coils. It was really tough stuff...
    At Lockheed, we used 2-part potting compound to encapsulate electrical
    connectors on the F-104G's that we were overhauling for the Luftwaffe.
    The engineers wanted to use red RTV instead of the old brown 2-part
    stuff. Dunno what it was, but it was very tough, compared to that
    crumbly red RTV...
    krusty kritter, Feb 22, 2005
  16. Torgeir Haukenes
    bob prohaska Guest
    Guilty as charged! :cool:
    I'd forgotten all about RTV silicone; thanks for the reminder!
    The self-leveling stuff, mixed with a little chopped fiberglass,
    might be just the ticket. Even better, work the white kind into
    fiberglass cloth and do a layup over the original manifold. A bit
    like the use of prepreg graphite epoxy composite. Maybe it could
    be vacuum-bagged before curing
    Making the cloth wrap smoothly will take some planning and effort, but
    it's far easier than trying to build a die for molding a complete
    new part.
    bob prohaska
    bob prohaska, Feb 23, 2005
  17. but it's far easier than trying to build a die for molding a >complete
    new part.
    That reminds me of another adhesive we used a lot of on the Apollo
    program. 3M weatherstripping cement, the yellow "gorilla snot" that
    dirtbikers were so familiar with in the late 1960's, before Loctite was
    commonly available...
    We needed to secure various small electronic cables to command module
    pressure vessel surfaces made of aluminum/honeycomb sandwich. We
    couldn't drill holes in the pressure vessel for screws to use regular
    electrical clamps, so we used fiberglass tape, impregnated with 3M
    weatherstripping cement. When that stuff cured, it stuck to the smooth
    aluminum surface like---like---like *glue*!!!
    We had to make up test coupons to be pulled apart on the same tensile
    strength tester that we used to test the epoxy bonding coupons made
    when we patched dings on the floor of the pressure vessel...
    So, maybe Torgeir could acquire some fiberglass tape and some 3M
    weatherstripping compound and wrap his rubber mainfold with that stuff
    and work the glue in. And, as it cured from the 200+ degree
    environment, the gorilla snot would get really, really, really *tough*!
    I don't know if it would get hard enough to crack and flake off, but,
    if it did, no big deal, start over with the white RTV silicone
    rubber...
    krusty kritter, Feb 23, 2005
  18. Thanks for your original reply, I liked that idea very much. And even
    more so now that I`ve gotten a quote on the molding job. Close to 1k
    usd for the mold and four manifolds was the price. That could buy me
    another old bike. Which I don`t need right now. Nor does the wife,
    she`s already having a hard time swallowing the Camel as she most
    fondly calls my Maico.
    So, I`ll check out the various ways suggested here to reinforce the
    original part.
    Thanks to everyone for their ideas and comments.
    TH
    `96 ZX6R
    `86 Maico 500
    Torgeir Haukenes, Feb 24, 2005
  19. And here am I, thinking I`m a crazy booger for merely wanting to make
    some molds and such... Thanks for the laugh, thanks again for the
    moral support and then for your advice.
    BTW, how did that forge work? Were you able to make a structurally
    sound part? Any info on the forge, pictures perhaps? I did mention
    machining earlier in the thread, yet casting the part - or a part of
    it - from metal is a notion that has eluded me. This needs thinking
    about.
    TH
    `96 ZX6R
    `86 Maico 500
Similar Threads
Loading...
