Ural fault-finding
Discussion in 'UK Motorcycles' started by platypus, Jul 6, 2010.
  1. platypus
    The brute wouldn't start. Eventually I found out why: no fuel. So I
    put some fuel in it, and found out why there was no fuel in it.
    Russian fuel hoses: no better than Ukrainian underpants.
  2. platypus
    crn Guest
    So the Urinal had been pissing on the floor.
    Figures
    crn, Jul 6, 2010
  3. platypus
    Eiron Guest
    Fuel hoses I have bought:
    Black with a cotton braid - cracked after a couple of years but only
    leaked where it was bent, i.e after putting the tank back on the bike.
    Green fluorescent - seemed to be petrol-soluble so shrank and hardened
    after a month or so.
    Goodyear from Halfords - perfect.
    Eiron, Jul 6, 2010
  4. platypus
    SIRPip Guest
    <crosses fingers>
    My tame oldBMWfreak, who is currently sweating over the Ural at this
    end, appears to have pinned the problem with this one down. The
    electronic ignition rotor/interrupter callitwhatyouwill has gone
    wobbly. Being Russian, it is made of several parts and they habitually
    come unglued, it seems. This gives rise to the symptoms ours was
    displying - will/won't run, will/won't start, will/won't spark, will
    die in the middle of junctions, that sort of thing. It could explain
    why it would run WFO or nothing I guess, with the speed of spin being
    sufficient to keep all the components in the right sort of place.
    Quite how he found the problem, he isn't letting on yet, but mebbe he
    will when I present him with the new one. Then once the beast is
    running, all we have to do is MoT it.
    SIRPip, Jul 6, 2010
  5. platypus
    SIRPip Guest
    What's wrong with the clear plastic with the internal reinforcing
    crisscross braid? I've used that for years with no problems whatsoever
    - available anywhere and cheap as chips.
    SIRPip, Jul 6, 2010
  6. platypus
    He bought another.
    Yes, I know....
    Hog, Jul 6, 2010
  7. platypus
    It's an incurable disease. I know someone with two Ural outfits and a
    Ural solo.
    wessie, Jul 6, 2010
  8. platypus
    As a former Beetle owner, I wouldn't touch the clear reinforced stuff
    with yours. In a VW application, it age-hardens, cracks, and sprays
    the interior of the engine compartment with a fine mist of fuel
    droplets.
    A few points:
    The Beetle is air-cooled, and there are some quite hot bits in there.
    The cooling fan draws its air from the fuel-misted engine compartment
    and blows it over the hot bits.
    The cooling fan also supplies this stoichometric mixture to the cabin,
    after warming in the heat exchangers.
  9. platypus
    You're bringing it to Chimay, then? It knows the way, it's been there
    before.
    <bounce>
    Err... Paging Kathryn.
  10. platypus
    Nige Guest
    Yep...
    Nige,
    'Candygram for Mongo'
    R1
    Nige, Jul 6, 2010
  11. platypus
    Paul - xxx Guest
    Or a film-makers ...
    Paul - xxx, Jul 6, 2010
  12. platypus
    sweller, Jul 6, 2010
  13. My Brother ran his Cossack on paraffin until he melted the heads
    back to the boats, Jul 7, 2010
  14. platypus
    This'll be what's wrong with TBC's Pan.
    platypus, Jul 7, 2010
  15. platypus
    Lady Nina Guest
    On Tue, 6 Jul 2010 06:19:09 -0700 (PDT), platypus
    Urals
    Mmm cobblestones. I'll not be there for this one though.
    Lady Nina, Jul 10, 2010
  16. platypus
    [Ural Fault Finding]
    they're shit. Job done - fault found.
    For vehicles associated with the Caspian Sea, you really want an
    Orlyonok.
    darsy, Jul 10, 2010
  17. platypus
    sweller, Jul 10, 2010
  18. platypus
    yes. I know. Thank you Rostislav Evgenievich Alexeyev.
    darsy, Jul 10, 2010
  19. platypus
    darsy, Jul 10, 2010
