Upgrade on 99 Kawasaki Nomad clutch???
Discussion in 'Motorbike Technical Discussion' started by dcstrng, Sep 15, 2003.
  1. dcstrng
    dcstrng Guest
    Has anyone got a short and sweet answer as to the least problematic
    way to upgrade the clutch on the Kawa G Model Nomad (carb 1999).
    I’ve got to tear into it this winter to see which oil-pump drive
    gear I have (replace if it is the plastic one) and since the bike has
    a tad over 21K miles, now seems like a good time to replace/upgrade
    the clutch since the basket has to come out to replace the oil-pump
    drive gear.
    I have (sort of) deduced from what I read that the 1500 Mean Streak
    clutch spring will fit, as might the heavier 1600 Classic spring.
    Then of course there are the after-market variations – Barnett,
    etc., etc. But simple (cheap) is good, I am not inclined toward a
    wholesale replacement.
    Is anyone familiar with the upgrade/conversion and how did it go.
    Thanks, Larry
    99 Nomad
  2. dcstrng
    dcstrng Guest
    dcstrng, Sep 16, 2003
