Update on the rounded nut situation.
Discussion in 'UK Motorcycles' started by eatmorepies, Mar 25, 2011.
  1. eatmorepies
    eatmorepies Guest
    Reference CB400T oil filter cover nut.....
    Thanks for all the suggestions - the 6 sided socket did the trick. I'll be
    sourcing a set of those then.
    John
  2. eatmorepies
    I can highly recommend this set:
    http://www.machinemart.co.uk/shop/product/details/cis1235-35pce-38in-1-2
    in-impact-sock/path/air-impact-socket-sets
    I use them for pretty much everything, with & without rattle gun.
    Krusty, Mar 25, 2011
  3. eatmorepies
    SIRPip Guest
    I bought a rack of Snap-On six-point Flank Drive impact socket decades
    ago, long before I had any means of driving them apart from manually.
    I used them for rounded, corroded, nadgery tight bastard fasteners and
    they put up with being hammered on to oversized heads very well. The
    nuts took some punching out afterwards, sometimes. They are, indeed,
    the dog's danglies.
    SIRPip, Mar 25, 2011
  4. eatmorepies
    SIRPip Guest
    Once you've got them (Machine Mart or Halfords Pro are prolly the
    easiest decent gear to lay your hands on for sensible money) then don't
    use anything else. I'll only use 12-point stuff in specific situations
    these days - like really tight access stuff, where I'm struggling to
    swing a ratchet or to get on it in the first place.
    6 points that drive on the flats - there's no real alternative.
  5. eatmorepies
    zymurgy Guest
    Runflat sockets. Have to get me a set of those :)
    Paul.
    zymurgy, Mar 25, 2011
  6. eatmorepies
    SIRPip Guest
    Denovolicious, man.
    SIRPip, Mar 26, 2011
  7. eatmorepies
    zymurgy Guest
    Heh. Forgot about the old Denovo, but was looking about and happened
    upon this :
    http://en.wikipedia.org/wiki/Tweel
    On a slightly more socket related note, I took a look at that set of
    UJ sockets I mentioned a while back, and they are indeed metric, from
    10mm to 19mm in 1mm increments.
    I'll let you and the speedyspic duke it out ..
    Paul.
    zymurgy, Mar 29, 2011
  8. eatmorepies
    SIRPip Guest
    Bring 'em to BOSM and I'll give you cash for them.
    SIRPip, Mar 29, 2011
  9. eatmorepies
    You cheeky ****, you know I can't make it to BOSM :)
    Lozzo
    they churn out)
    Lozzo, Mar 29, 2011
  10. eatmorepies
    SIRPip Guest
    <whistles>
    I'm collecting your Scottoiler parts for you, sounds fair to me.
    SIRPip, Mar 30, 2011
