Unique Bikes
Discussion in 'Australian Motorcycles' started by Don Ricciardiello, Dec 4, 2005.
  1. Don Ricciardiello, Dec 4, 2005
  2. Don Ricciardiello
    JL Guest
    Nice, what engine you putting in the hossack FFE bike ?
    JL
    JL, Dec 4, 2005
  3. Don Ricciardiello
    Sprint Guest
    Nice Supermono. What material are the forks made of in the last couple of
    images?
    Sprint :)
    Sprint, Dec 5, 2005
  4. The legs are made of 50mm dia. carbon tubes with a 3mm wall thickness
    sourced from www.compositespars.com They're incredibly stiff. Their short
    length helps here too. The axle/caliper clamps are bonded to the carbon
    tubes with an adhesive called Hysol EA9394. To be sure of the bond strength
    we lifted a 2 tonne concrete block with a sample piece and then asked the
    crane operator to jerk the load up and and down to really load it up. There
    was no visible degradation of the bond so we're confident it'll hold up to
    bike racing. Not particularly scientific I know but confidence inspiring
    none the less.
    Don
    Don Ricciardiello, Dec 5, 2005
  5. Going with a hotted up TL1000R motor this time around. Should be fun!
    Don
  6. Don Ricciardiello
    ysidro Guest
    my Royal Enfield is higher tech than these bikes :)
    Y.
    ysidro, Dec 5, 2005
  7. Don Ricciardiello
    JL Guest
    Damn fine idea :)
    JL
    04 Cagiva X Raptor -> hotted up TL motor :)
    JL, Dec 5, 2005
  8. Really? Don't I recall something about the smaller airbox actually
    resulting in a few _less_ hp than the TLR???
    pedant-big
    Iain Chalmers, Dec 6, 2005
  9. Don Ricciardiello
    sharkey Guest
    Noice!
    -----sharks
    sharkey, Dec 6, 2005
  10. Don Ricciardiello
    JL Guest
    Nope, there's Italian ponies and Japanese ponies, it comes with the
    Italian ones now :)
    It is actually up 4 HP IIRC (1) -Suzuki report crank HP, Cagiva Rear
    wheel HP, but when you compare the dyno charts the wogs have managed to
    squeeze an extra couple of ponies and some extra torque comparing stock
    with stock. They changed the cams, the exhaust and the efi again IIRC,
    the focus was on torque improvement though. When you swap to aftermarket
    pipes and a power commander you can get the same peak HP out of both (up
    about 10 on stock(2)) but with more torque and a bit lower in the rev
    range on the raptor.
    The lower gearing is a far more noticeable in the real world
    JL
    (1) Like that makes much difference
    (2) which mine isn't 'cos it needs dyno tuning I'm running a map off the
    PC website which is too rich
    JL, Dec 6, 2005
  11. My brother, I just watch and drool!! He's a machinist by trade and does all
    his own CAD design work and CNC machining. Having worked in that environment
    for years you pick up all the other skills like welding, sheetmetal work,
    composite fabrication etc. I really must put a comprehensive site together
    for him to really show off some the bits and pieces he has made over the
    years. He helped me a lot with my hybrid
    http://www.thumperpage.com/articles/XRG660.html which is nowhere near s
    trick as a custom chassis.
    Rgds,
    Don
    Don Ricciardiello, Dec 6, 2005
  12. Whereabouts are you from? We're in Western Sydney. If you're nearby you're
    welcome to drop in and have a look. Reading Tony's Book
    http://www.tonyfoale.com/ is a great start. Also have a look at Michael
    Moore's Eurospares site http://www.eurospares.com/ for lots of good info and
    links to the mc-chassis design e-mail list where the likes of Ian Drysdale
    and other like minded souls hang out.
    Rgds,
    Don
  13. Well look at that! Its *NEW* *IMPROVED* "Worms-in-a -can"(tm)!!!
    big (Welcome back Alice, long time no see - at least not in here...)
    Iain Chalmers, Dec 7, 2005
  14. Don Ricciardiello
    What's the frame on the TL1000S?
    They were a "deltabox" chassis and alloy swingarm standard weren't they?
    That one looks a bit Ducati-like (and that swingarm LOOKS very flimsy!)
    Knobdoodle, Dec 9, 2005
  15. Don Ricciardiello
    IK Guest
    Deltabox is a Yamaha thing, dude... the TL-S runs an aluminium-tube
    trellis main beams with castings for the headstock and rear endplates
    Yup. Essentially the same unit as contemporary GSX-R600's
    You thought so, too, huh... notice, though, the cross-members between
    the overbrace and the arms themselves. That'll be helping matters a bit.
    IK, Dec 9, 2005
  16. Don Ricciardiello
    IK Guest
    Has that thing of yours been in a bikemag yet?
    IK, Dec 9, 2005
  17. Don Ricciardiello
    Yeah I know but Yamaha pretty-much pioneered the alloy beam frame so old
    refuse-to-acknowledge-anything-is-original buggers like me refer to that
    style of frame as a "deltabox" (with quotation marks around it so that
    people know we're not being literal).
    Ahh yes. That style carried on to the SVs too.....
    I'm sure that with Reynolds 531 (or whatever the "gun" [not a real gun, IK]
    tubing is) and good design (which this one appears to have) and manufacture
    a light tube swingarm could be quite strong.
  18. Don Ricciardiello
    JL Guest
    Benelli thought it was an explosive idea
    JL
    TnT - geddit ?
    JL, Dec 9, 2005
  19. The frame is a standard(ish) trellis format of his own design and
    manufacture. The photo doesn't clearly show it but the tubes and
    bracing of the swingarm is substantial. My brother ain't the fastest
    rider around but he can't make it misbehave.
    Rgds,
    Don
    Don Ricciardiello, Dec 13, 2005
  20. The completed TL powered bike was due to feature in Streetbike but
    never made it for various reasons. It's currently being stripped down
    after a hard but reliable racing season to check things over for wear
    and tear. So far so good, only one minor crack on a radiator mount
    bracket. When rebuilt it's off to the dyno to sort out a new ECU put
    together by Cliff Jeffries
    http://www.cajinnovations.com/MyECU/latest.htm which shows promise of
    being better than the current stock ECU and Power Commander set-up. The
    new Hossack derived bike will definitely make it to press, I'll insist!
    Rgds,
    Don
