umm oh there it is .....
Discussion in 'UK Motorcycles' started by wsotw, Apr 1, 2005.
  1. wsotw
    wsotw Guest
    err... hello.....again
    OK straight back in with the questions
    I am putting my 748 back on the road in the next month.
    since the EOSM 2003 it has done ooh about 6 miles. It's been garaged all
    the time. It's last service then was about April 2003, in the period
    from April to the EOSM it did about 600miles.
    Basically it will need an MOT (no problems there) but I am wondering
    about a service.
    I can only just about afford to put it back on the road and maybe have a
    w/end run one or so a month.
    Servicing myself (stop sniggering) is something I am not really willing
    to do.
    Should I just not bother about a service or have a basic oil/plugs and
    check over done? (which should cost in the region of?)
    Oh and just in case I didn't make it clear - I have just enough to
    tax/insure it.
    I want to keep the costs down as much as possible.
    (oh and hello to AndrewR - your help was appreciated muchly)
    wsotw, Apr 1, 2005
  2. wsotw
    tallbloke Guest
    Hi Colin.
    Lots, because getting the fairing off and back on a 748 is a pain in the
    arse. 606 miles is **** all. Just Ride The Bloody Thing.
    Sell it and get a cheaper to maintain bike that uses less fuel. Then you'll
    be able to afford to ride three times a month instead of once.
    tallbloke, Apr 1, 2005
  3. wsotw
    I'd change the oil at least. Someone once told me that you need to be
    a bit anal about servicing Ducatis or it gets expensive.
    SWK will be along soon.
    Pip Luscher, Apr 1, 2005
  4. wsotw
    wsotw Guest
    I'm still in this shithole of a world is about as good as it can be
    described.
    Seriously need a job and some money and some other stuff too.
    nah this was way way earlier this year
    wsotw, Apr 1, 2005
  5. wsotw
    wsotw Guest
    well It did go through my mind, but I decided against that as it is all
    paid for etc. and tax/insurance isn't that much, I like the bike etc.
    wsotw, Apr 1, 2005
  6. wsotw
    wsotw Guest
    I think If I had your attitude (meant nicely), the last year would not
    have gotten to me so much.
    I'm not going to let the cunts stop me from having a life. Thats why I
    want the bike back on the road.
    I know nothing about them.
    wsotw, Apr 1, 2005
  7. wsotw
    Colin Irvine Guest
    Good. Keep in touch.
    Colin Irvine, Apr 1, 2005
  8. wsotw
    antonye Guest
    Service it - no questions at all.
    The belts should be replaced every 12K miles OR 2 years.
    The yearly bit is because the run of the belts is very tight
    and leaving it standing for any long period of time will mean
    that the belts harden around the tightest part. Start it up
    and chances are you'll jump some teeth and you *really* don't
    want that to happen.
    Don't worry, it's not an easy job, requires a few specialist
    tools and the cambelt tension is not something you want to guess.
    Unfortunately the cost of a full service including belts is
    in the region of 4-500 quid all in. It's not the cost of the
    belts as they're only 22 quid each, but the 4+ hours of labour
    it takes to fit and then another 4+ for the rest of the service.
    There's no need for a full service unless you're really anal.
    This would change all the fluids (oil, water, brake, clutch,
    fork oil) and give the bike a real going over. A minor service
    may be enough but you've hit the 2-year limit and was it a
    full service last time? It could have been 4 years since your
    brake fluid was last changed.
    Depending on where in the country you are, there are plenty
    of really good recommended unofficial Ducati service places
    which charge about half the superstore rate and probably do
    a better job. Remember that your average UJM servicing place
    will either not touch it or not have a clue what they're
    doing anyway.
    Having a bike like a Ducati and then scrimping on servicing is
    false economy. Pay the service bill or you may be either writing
    off the bike or buying a new engine, and that's not cheap.
    Sorry to be the bearer of bad news!
    antonye, Apr 1, 2005
  9. wsotw
    wsotw Guest
    wsotw, Apr 1, 2005
  10. wsotw
    antonye Guest
    Modern?!? The racebike is a 1997 FFS! That's not modern!
  11. wsotw
    wsotw Guest
    oh it has'nt just sat in the garage, it's been turned over and ran very
    few weeks. also, its a 2001 bike and the April 2003 service was about
    that price...in fact......
    got the "invoice/work" schedule here:-
    11/4/03 - cam belts,fuel/oil filter,shim,nut,spark plugs, brake fluid,
    air filters, coolant, decal (injection/ecu under seat - don't know what
    they did) and new tyre (puncture)
    total 612 inc. vat
    So I would say that was big service, but do you really think it needs
    doing again after only 600 miles?
    I know what you mean, and If I were working it would have the care it
    deserves but I'm not and need to keep the costs to a minimum.
    wsotw, Apr 1, 2005
  12. wsotw
    antonye Guest
    Service intervals are 12 Miles OR 2 years.
    It's your gamble!
  13. wsotw
    antonye says...
    And they say Kawasakis have short service intervals
    Lozzo, Apr 1, 2005
  14. wsotw
    tallbloke Guest
    Col. Don't take advice from people without bikes.
  15. wsotw
    tallbloke Guest
    Heh. :)
    I'd say if Colin has turned it over every few weeks, and only done 606 miles
    since the cam belts were replaced, he could easy put another 10k miles on the
    bike without worrying. Change the oil after another 500 miles though as it
    may have a bit of condensation buildup
    tallbloke, Apr 2, 2005
  16. wsotw
    Colin Irvine Guest
    You might get away with that on a decent Jap bike - not on an Italian
    one.
    Colin Irvine, Apr 2, 2005
  17. wsotw
    tallbloke Guest
    ISTR HONDA vfr's having cam drive 'issues' not so long back.
    FWIW I liked the old desmo Ducati engines. Quality valve control.
    I don't suppose the belts in a ducati are any different to the belts in a
    japper though.
  18. Not really, only the crank sprocket/pulley is quite small and the belts
    have to turn through quite a tight bend. I think if you had a DOHC Jap
    sports bike with belt drive to the cams, then they'd need frequent
    replacement too.
    The Older Gentleman, Apr 2, 2005
  19. tallbloke wrote
    Not so long back and stretching into the distant past.
    Prolly all made by the same firm in Nuneaton/China anyway.
    steve auvache, Apr 2, 2005
  20. wsotw
    tallbloke Guest
    A mere wink of an eye for you and me Steve.
