ultrasonic cleaner
Discussion in 'Classic Motorbikes' started by Austin Shackles, Mar 19, 2007.
  1. OK, the destructions say to use water. has anyone tried other working
    fluids, or adding soap, or suchlike, and if so with what results?
  2. Austin Shackles
    JB Guest
    So far:
    (Flat!) coca cola for gummed up carb jets/emulsion tubes/needles.
    Water/washing up liquid general small parts degreasing.
    Flash liquid/water. (this has an awesome cleaning power).
    Not tried trike or other solvents yet.
    JB
    JB, Mar 19, 2007
  3. Austin Shackles
    Naqerj Guest
    I've used white spirit and it works. The destructions say not to use
    solvents but I reckon thats 'cos the liquid gets warm while its working.
    As long as you use it somewhere thats well ventilated and you don't
    light up next to it, there's no promble.
    Naqerj, Mar 19, 2007
  4. cool. Mind, it's amazing what it does with just plain H2O.
  5. Austin Shackles
    When I worked at HP in Bristol, we had a big ultrasonic jobby in the
    prototype area. First tank was Teepol, second and third were water.
    Breathtakingly effective with trainers, as it happens...
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Mar 19, 2007
  6. Austin Shackles
    JB Guest
    You want to see what it will do with coca cola with the fizz still in it :>)
    JB
    JB, Mar 19, 2007
  7. Austin Shackles
    JB Guest
    Putting the brown in to Brown Sauce since 1976.
    JB
    JB, Mar 19, 2007
  8. What ultrasonic widget are you using?
    I've been thinking of buying one. Can anyone recommend a
    make/model/price/source?
    The Older Gentleman, Mar 19, 2007
  9. elcheapo one from Aldi or somesuch. a friend picked it up for me. Small,
    mind, it holds just over a pint of fluid. handy for small things though. I
    did me watch, took about 5 or 6 goes but it successfully degunged the
    expanding metal bracelet with almost no effort.
    tried the tea strainer, with mixed results. got to find out what fluid
    dissolves tannin. coke might...
    Austin Shackles, Mar 20, 2007
  10. yes, it is. point noted.
    hehe.
  11. Austin Shackles
    Howard Guest
    Ammonia is smelly but it works. Dilute it of course
    Howard, Mar 20, 2007
  12. Austin Shackles
    Roger Hunt Guest
    Mark wrote
    That is useful to know - I got an Aldi one and the first thing I did was
    throw away the Manual.
    Roger Hunt, Mar 20, 2007
  13. Sounds like Mark's got a spare one if you need it...
    Dr Ivan D. Reid, Mar 20, 2007
  14. Austin Shackles
    Roger Hunt Guest
    Dr Ivan D. Reid wrote
    Probably saturated with Coca-cola and several other noxious liquids, and
    unreadable with the pages stuck together, but thanks for the thought.
  15. Austin Shackles
    Moon Badger Guest
    Paraffin works OK on tarry/oily deposits, and is very good at de-gunking
    carbs. Doesn't make them shine, but does dissolve gummy deposits.
    Flat cola drinks, preferably sugar free have their uses for cleaning metals.
    Detergent designed for automatic washing machines has its uses.
    Dishwasher tablets work OK too. Not a whole tab though.
    Dilute acetic acid works wonders on Mazak. Not bad at shifting corrosion or
    at least making it easier to shift. Like cola drinks, the acid seems to
    lift the surface up a notch too..
    Dilute Gunk and other cleaners of that ilk.
    Dilute ammonia.
    Things not to use.
    Petrol, or indeed anything that produces a flammable vapour or mist. ( H&S )
    Washing up liquid or detergents without foam suppressors. Just work out how
    I know that one. The soapy bubbles produced are incredibly fine. That may
    be down to the bath I was using and the object in it though. ( can be
    messy )
    Neat vinegar or undiluted stop bath. Causes mild issues with breathing if it
    produces a mist. ( can also damage/eat metal )
    For complex shapes, don't just run the bath for hours on end, run it for a
    while ( within the duty limits ) then rotate the object in the bath.
    Try and avoid resting the object to be cleaned on the base of the bath. If
    it has a basket, use it, or suspend the object in the bath.
    I must get another. Damn useful things they are.
    Moon Badger, Mar 20, 2007
  16. hmmm. the book of words for this one says cleaning power is reduced by
    about 30% if you use the basket thing, which seems to imply otherwise.
  17. Austin Shackles
    Roger Hunt Guest
    Austin Shackles wrote
    I thought the basket was more to stop things rattling in an irritating
    manner, and to stop delicate things rattling around and getting scuffed.
  18. Austin Shackles
    Tim Guest
    "Decon 90" surface cleaner and "Hibiscrub" have been used to clean
    carbs from time to time.
    Tim, Mar 20, 2007
  19. Austin Shackles
    Moon Badger Guest
    *Ding*
    Actually, suspending the object in the bath seems to work best ( for me ),
    but it is a faff. This way, the basket doesn't get in the way, things
    aren't scuffling about in the bath, and it doesn't make irritating noises
    just on the threshold of your hearing range. Noises that make you want to
    kill. That may again just be me.
  20. Austin Shackles
    Ken Guest
    Flash spray with bleach is almost magical at cleaning teapots &
    strainers etc
    Ken, Mar 20, 2007
