Ultraseal - opinions ?
Discussion in 'UK Motorcycles' started by C J Fleming, Aug 31, 2003.
  1. C J Fleming
    C J Fleming Guest
    Having seen off the erstwhile spammer, this prompted me to enquire if
    anybody here actually DOES use the stuff ? My inexperienced instincts
    suggest "snake oil" but does anyone have any hands-on, so to speak, comments
  2. C J Fleming
    Ben Blaney Guest
    Never even heard of it. Mind you, I have clean fingernails.
    Ben Blaney, Aug 31, 2003
  3. C J Fleming
    Ginge Guest
    Also, does anyone know how much liability insurance the manufacturers
    and retailers of these products carry? I assume at some point they must
    have failed and injured or killed someone.
    Ginge, Aug 31, 2003
  4. Bear said:
    Bridgestone and others do - for their huge tyres fitted to quarry
    machinery etc.
    Simon Atkinson, Aug 31, 2003
  5. Bear said:
    You could have just posted a 1. I'd have known what 'joke' you meant
    then...
  6. Bear said:
    Could go either way at the moment... It'll be a relief when it's
    finished.
  7. Bear said:
    S:)
  8. C J Fleming
    pete boyall Guest
    Probably, but I'm a) Lazy and b) Clueless, so Tyre-weld will do for me
    pete boyall, Aug 31, 2003
  9. C J Fleming
    porl Guest
    Lack of desperation.
    porl, Aug 31, 2003
  10. C J Fleming
    Sean Guest
    Your fecking what?
    Sean, Aug 31, 2003
  11. C J Fleming
    "Bear"
    I have a quick look around the rubber bands most times out.
    Hog, Aug 31, 2003
  12. C J Fleming
    linger Guest
    In
    The 6 odd wings that I travelled with on the tunnel all had it in and swore
    by it.
    So it's ok for wings.
    linger, Aug 31, 2003
  13. So it deflects nails, broken glass, and other sharp objects?
    Twat.
    The Older Gentleman, Aug 31, 2003
  14. C J Fleming
    You're not wrong
    I look at the oil level too and a general sanity check
    Hog, Aug 31, 2003
  15. C J Fleming
    Salad Dodger Guest
    Consider the time required to effect a repair to a damaged tyre, and
    you'll see why.
    Unless they had 1800s, which are a piece of piss to change the wheel
    on.
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..58320../..13655.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17
    \|^|/ 2003 RBR landmarks:99 points:2100 miles:8000
    Salad Dodger, Aug 31, 2003
  16. C J Fleming
    Preston Kemp Guest
    Oh ffs. Okay, I'll re-phrase it for the terminally pedantic. I've never
    had a deflation as a result of a puncture in a Slimed tube.
    Preston.
    http://www.muddystuff.co.uk
    Off-road motorcycle classifieds
    '02 MV Senna '96 Tiger '00 XR400 '78 Fantic 250
    Preston Kemp, Aug 31, 2003
  17. C J Fleming
    linger Guest
    In
    They all had 1800's but they all raved about Ultraseal.
    It was like a QVC ad the way they dropped it into the conversation.
    I thought I was part of the Truman show!
    linger, Sep 1, 2003
  18. I'm not arguing with you bvecause I happen to think US is crap, or any
    good, or even God's Gift. I'm arguing with you because you're a twat and
    it must be done.
    And you appear to know just enough about bikes to make your scanty
    learning a dangerous thing.
    The Older Gentleman, Sep 1, 2003
  19. This tyre gunge has been around, in one form or another, for decades.
    It *can* stop catastrophic blow-outs on tubed tyres, but on modern
    tubeless tyres it's a bit of a waste of time, effort, and it has several
    *very* questionable safety points (one of which is wheel balance, but
    I'll leave that for another day).
    I've talked about it with several tyre manufacturers, and *none*
    recommends its use, although (as ever) a certain amount of CYA comes
    into play here.
    Unfortunately it appeals to the less mechanically-minded types (the sort
    who tend to fit those little tyre pressure indicators on their valve
    stems), and like all people who know very little, but just enough to
    make them think they know lots, they extol its benefits.
    All it is is pre-applied Finilec, or Tyre Weld, when all is said and
    done and pre-fixing a puncture.... well, the old adage: "If it ain't
    broke, don't fix it," comes to mind.
  20. C J Fleming
    What? Finally a sensible, infomative answer? You must be slipping
    Neil.
    Ace, Sep 1, 2003
