UKRM Run 2010
Discussion in 'UK Motorcycles' started by Cab, May 2, 2010.
  1. Cab
    YTC#1 Guest
    Hmmm, if only Colin had a middle name, like Robert.
    YTC#1, May 4, 2010
    #81
  2. Cab
    Kiran Guest
    "Interesting" only on your speedo. Either mine is pretty accurate or
    yours is *waay* out.
    Kiran, May 4, 2010
    #82
  3. Cab
    Mosel/Eiffel Mountains would be nice. Trier is a pleasant city with plenty
    to do if it pisses down. Family run hotel I've used in the past would be
    too small, glorified B&B really. 300 miles from Calais though.
    wessie, May 4, 2010
    #83
  4. Cab
    YTC#1 Guest
    I looked over Jordan, and what did I see ?????
    YTC#1, May 4, 2010
    #84
  5. Cab
    zymurgy Guest
    Lazy cunts, the pair of you ..
    Paul.
    zymurgy, May 4, 2010
    #85
  6. Cab
    zymurgy Guest
    Germany, are you stark, staring mad ... ?
    A mere trifle ..
    Paul.
    #86
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    I, for one, should be most disappointed if it were to be anything other
    than a "French Run".
    Wicked Uncle Nigel, May 4, 2010
    #87
  8. Cab
    Wuss.
    Lozzo, May 4, 2010
    #88
  9. Cab
    Colin Irvine Guest
    It won't be.
    Colin Irvine, May 4, 2010
    #89
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    I *knew* you were the right man for the job.
    #90
  11. Cab
    YTC#1 Guest
    A band of white Angels, coming for to carry me hoooommmeeee
    YTC#1, May 4, 2010
    #91
  12. Cab
    YTC#1 Guest
    have a "be"
    YTC#1, May 4, 2010
    #92
  13. Cab
    I will, and I'd sooner do it there than in Switzerland, but I'd restrict
    my journey to autobahns where possible as a means of getting across the
    country to somewhere further east (where they probably still report you
    to plod but you can bribe your way out of trouble at a more reasonable
    rate)
    ogden, May 4, 2010
    #93
  14. Cab
    dozynsleepy Guest
    Feck off. I had to spend time with my family, is that not punishment
    enough ?
    dozynsleepy, May 4, 2010
    #94
  15. Cab
    Cab Guest
    As WUN said, it's got to be a "French" run. I'll check out some interesting
    places if TOG hands over the reins to Colin.
    Cab, May 4, 2010
    #95
  16. Cab
    Quite right too; the words 'French' & 'run' do go awfully well together.
    Krusty, May 4, 2010
    #96
  17. Cab
    I'm sure it'd be fine, but probably best to shoot everyone you overtake
    just to be on the safe side.
    Krusty, May 5, 2010
    #97
  18. Cab
    Colin Irvine Guest
    Super. And we've already had requests to return to Caudebec, Bayeaux
    and Chepy!
    Colin Irvine, May 5, 2010
    #98
  19. I've considered Belgium and Holland in the past, the difficulty being
    the distance from home in the time available. Plus the factor that,
    while 200 miles in the rain is a PITA, 400 miles is worse.
    The Older Gentleman, May 5, 2010
    #99
  20. Cab
    As far as I'm concerned they're all the same once they've got you
    nailed and all you can do is pay the fine then get out of the country.
    Andy Bonwick, May 5, 2010
