uk.rec.cycling
Discussion in 'UK Motorcycles' started by AndrewR, Jun 23, 2009.
  1. AndrewR
    bookieb Guest
    On Jun 26, 10:51 am, "Dave Larrington" <>
    wrote:
    What manner of brakes are on that?
    Rear wheels appear to be unbraked, but are there two on the front
    wheel?
    Regards,
    Bookieb.
    bookieb, Jun 26, 2009
    #61
  2. AndrewR
    TOG@Toil Guest
    This is one of those postings that is crying out for a "More details,
    please!" request. So here it is.
    TOG@Toil, Jun 26, 2009
    #62
  3. In
    Yep, cantis and a dual-pivot. I suspect it was originally built for 27"
    wheels rather than 700s, which is why some bodging has been the order of the
    day to make the bloody things fit.
    Dave Larrington
    <http://www.legslarry.beerdrinkers.co.uk>
    World Domination? Just find a world that's into that kind of
    thing, then chain to the floor and walk up and down on it in
    high heels.
    Dave Larrington, Jun 26, 2009
    #63
  4. Well, now there are only 9,999,999 bicycles in Beijing.
    Grimly Curmudgeon, Jun 26, 2009
    #64
  5. <Snip>
    Britian is proud of you :))
    The Older Gentleman, Jun 26, 2009
    #65
  6. Been busy, then?
    #66
  7. A simple 'heh' would have sufficed.
    #67
  8. AndrewR
    Guest Guest
    Are both brakes on the /front/ wheel? that may explain the difficulty. Is
    there no way that brakes could also be on the rear wheel? Discs? Hub brakes?
    Guest, Jun 26, 2009
    #68
  9. AndrewR
    Guest Guest
    Passing Vaux brewery (no longer extant) on my way to school, It was a
    superniff on some days, but Ooerr!!! on others.
    Guest, Jun 26, 2009
    #69
  10. AndrewR
    Rob Morley Guest
    Two brakes on the front wheel is the traditional solution for trikes,
    because they're legally required to have two independent brakes and rear
    brakes are a load of hassle and not much use. With modern hydraulic
    discs it would be easier to fit effective rear brakes, but I think it
    would make more sense to have a disc and a rim brake at the front
    unless the trike was designed to carry heavy loads.
    Rob Morley, Jun 27, 2009
    #70
