Tyre wear/suspension setup
Discussion in 'UK Motorcycles' started by jlittler, May 22, 2005.
  1. jlittler
    jlittler Guest
    Hi all
    4 week old 04 Cagiva X Raptor.
    Running 180 rear, 120 front (Bridgestone I think, I
    can check if you think it's relevant), I've got wear marks right to the
    edge on the rear, but I've still got about a finger's width of
    untouched tread on the front. I seem to recall that indicated that I
    didn't have the suspension set up right - comments, suggestions ?
    I've not taken it to a track yet, just road riding, have about 3500Km
    on it. Started setting up the suspension this weekend, the front was
    too stiff so I backed off the preload a fair bit (sag is about right
    now) and the compression damping a little bit. It was a lot better up
    McCarr's Creek road today (the benchmark for rough as crap roads in
    Sydney), although I think it could go a little softer. I've left the
    rear stock so far, although I suspect it could be backed off a little
    (I'm doing as much 2 up riding as solo and the setup seems about right
    for two up).
    Suggestions ?
    JL
  2. jlittler
    tallbloke Guest
    wrote in @g44g2000cwa.googlegroups.com:
    Just ride the fucking thing. :)
    But by all means play with the suspension settings. Do it gradually though,
    and always remember where the standard settings are. Eventually you'll know
    where you want to set them for various types of road conditions and speeds
    and weights etc.
    tallbloke, May 22, 2005
  3. jlittler
    jlittler Guest
    Shit mate, I've done 3500K in 4 weeks, I am bloody riding it !! Every
    chance I get <grin>.
    JL
    (I just seem to recall the uneven wear thing indicating a suspension
    setup issue, but can't find the answer via google)
  4. jlittler
    I doubt it's anything to do with suspension, unless you can't lean far
    enough to take the front to the edge before something grounds out. The
    tread on fronts always wraps around further than on rears (assuming a
    matched pair), so you simply have to lean further to take a front to
    the edge.
    Krusty, May 22, 2005
  5. jlittler
    tallbloke Guest
    wrote in @f14g2000cwb.googlegroups.com:
    3 1/2 million miles in 4 weeks is some going ;-)
    If you think about the wear thing logically, all it means is that the cross
    section radius on the front tyre is tighter than the rear. Considering how
    much wider the rear is than the front this is not surprising. Stop worrying
    about it. Who'd want to be right to the edge of the front anyway?
    If the suspension feels right, it is right.
  6. jlittler
    dwb Guest
    Though leaning that far potentially will have the whole bike over :)
    I went off the front of the GSX-R doing a low speed "knee down"[1] day in a
    Qinetic car park - the first and only time I grounded anything on the GSX-R
    and the instructor suggested not leaning it any further :)
    dwb, May 23, 2005
