tyre was facing backwards
Discussion in 'Australian Motorcycles' started by W.D., Oct 28, 2003.
  1. W.D.
    W.D. Guest
    Well I'm home in central Queensland from the Island.
    But while in Brisbane I noticed the rear tyre (Michelin pilot sports) I'd
    had fitted before I left , was facing the wrong way. It had been mounted
    incorrectly by a usually good bike shop. Luckily I had to ride in very
    little rain the whole trip. I had even went about as hard as I could up the
    mountain from Cann river (o/t - I wish they had more service stations there)
    and it doesn't seem to have been a problem. Has anyone else had a experience
    like this?.
    W.D.
    "DUCATI" not perfect but
    we win world championships
    W.D., Oct 28, 2003
  2. Hey that's handy - sorta like winding back a speedo, you should get an
    extra 2500km that you've just wound off it!
    Cheers
    (Glad to be of help)
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Oct 28, 2003
  3. How do you figure that?
    A number of race-compound tyres, such as Michelin Pilot Race and Dunlop
    D208GP, have front tread patterns which look "backwards".
    Intact Kneeslider, Oct 28, 2003
  4. W.D.
    Jessie Guest
    All it means is if you put your brakes on hard in the wet, you'll more
    likely lose control and slide longer.
    Jessie, Oct 28, 2003
  5. W.D.
    atec77 Guest
    you would not call him sexy if you had seen him .. > ugly fecker..
    atec77, Oct 28, 2003
  6. W.D.
    Jules Guest
    That's your technical summation of their configuration then?
    Jules, Oct 28, 2003
  7. Well, it's no less sophisticated than the assessment made by the OP, and it
    refrains from making any actual conclusions.
    What do you make of the tread pattern on a front D208, or a front Pilot
    Race?
  8. W.D.
    Jessie Guest
    The Dunlop team tested it on almost two years ago to the day. The tires
    facing the wrong way would lose about 2 metres in stopping distance
    everytime in hard braking in the wet. The tires would also be more likely to
    slip out when going on a hard lean into a corner. The only up side was there
    was less grove wear on the tire rubber, which ment the tires would probably
    last longer.
  9. With a Dunlop, that's probably a bad thing. It means more time and km's
    until it wears out and gives you an excuse to replace it with a decent tyre.
    In any case, why didn't you just say the above to begin with? And what sort
    of psychopath expects wet-weather performance from a sports tyre?
    Notice how I keep typing "tyre"?
  10. W.D.
    Dane Guest
    me? :)
    AND LOOK HOW THAT TURNED OUT?!?!?! heh.
    Dane, Oct 28, 2003
  11. My tyres don't have *any* trees on them (even in the grooves)...
    Postman Pat
    Pat Heslewood, Oct 28, 2003
  12. W.D.
    sharkey Guest
    I'm tiring of it.
    -----sharks
    sharkey, Oct 28, 2003
  13. W.D.
    conehead Guest
    Perhaps the tyre was put on correctly, but your bike was pointing the wrong
    direction when the wheel was put on the bike. Shyt happens.
    conehead, Oct 28, 2003
  14. W.D.
    Jules Guest
    Never paid much mind to be honest. They're not tyres I'd be choosing if I was planning on wet weather riding.
    Jules, Oct 28, 2003
  15. W.D.
    I never weary of it.
    Knobdoodle, Oct 28, 2003
  16. W.D.
    Damn damn damn **** damn poo wee bloody-blithering BUM!!!
  17. W.D.
    knobdoodle Guest
    WTF?
    Clem
    [cynicism is all tool rampart]
    knobdoodle, Oct 28, 2003
  18. W.D.
    conehead Guest
    "Where's The Freckle?" says Crem
    Conehead
    Nugget my starfish, you burly oafs!
  19. I'll second that. 8000k's and the fucken shit D207's are still going strong.
    No grip but they still have tread so I'm loathe to replace them. It is
    however loads of fun sliding them around...
    Aaron
    ZX6R
    Aaron & Kylie, Oct 28, 2003
  20. W.D.
    Fwoar Guest
    Wow - a 2 metre extra in stopping distance.
    What happens if it's the front tyre thats backwards??
    Note : Its the rear tyre that was fitted backwards
    What happens if you put a rear tyre on the front but turn it around so it
    runs backwards??
    Yes I have done this on an FJ1200..
    Daron
    Fwoar, Oct 28, 2003
