Tyre recommendations please...
Discussion in 'UK Motorcycles' started by Fubar Bundy, Apr 24, 2008.
  1. Fubar Bundy
    Fubar Bundy Guest
    On the back of my m/cycle, I have a Dunlop D401 (150/80) Not overly
    impressed with the grip when accelerating on tight corners. Can anyone
    recommend a better-gripping tyre that's affordable?
    I'll also want to replace the front tyre at the same time. Also, if
    anyone could point me to an online supplier with good prices, that
    would be appreciated...
    FD
  2. Fubar Bundy
    Fubar Bundy Guest
    PS,
    I mainly commute on twisty country roads, and like to be sure-footed
    on such things as roads that are banked the wrong way, and when
    accelerating out of junctions and suchlike. Good grip on corners is my
    prime concern. Price, and longevity of tyre are also a concern.
    FB
  3. Fubar Bundy
    Derek Turner Guest
    Horses for courses. What fucking bike, wanker?
    Derek Turner, Apr 24, 2008
  4. Fubar Bundy
    What bike?
    Try http://www.blackcircles.com/bikes
    I managed to get tyres from a local(ish) place for much the same price.
    Other places locally wanted £40 more for a pair.
    The UKRM FAQ lists some tyre places
    http://www.ukrm.net/faq/Bike_Maintenance/Tyre_dealers.html
    wessie, Apr 24, 2008
  5. Fubar Bundy
    It's a 150/80 tyre, ergo, the bike is shite
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 24, 2008
  6. Fubar Bundy
    Fubar Bundy Guest
  7. Fubar Bundy
    Fubar Bundy Guest
    2005 XL 883C
    Cheers,
    FB
  8. Fubar Bundy
    Derek Turner Guest
    We snip in this ng.
    I'll hazard Bridgestone BT020 but it still won't go round corners.
  9. Fubar Bundy
    Derek Turner Guest
    So sorry, as you were.
  10. Fubar Bundy
    Fubar Bundy Guest
    Yes, someone else suggested those.
    Earlier Sportsters may have been poor on corners for other reasons
    besides the tyres. My 1998 XLl was hairy on corners, and I think it
    was the bike's geometry as well as the tyres, but this 2005 Custom,
    seems a lot better - except for the slippy rear tyre. It's possible
    the tyre is just be too old (3 yrs). I'm told the rubber hardens after
    a while, and loses stickability.
    FB
  11. Fubar Bundy
    crn Guest
    I doubt if 3 years is going to cause significant hardening. A lot depends
    on the compound but the front on the LE has just been replaced after
    30+ years and the rear is still OK. I would expect to see cracking on
    the sidewall if a tyre has gone hard.
    Check the pressure with an accurate guage, the recommended pressure will
    depend on loading. Using the 2-up pressure while riding solo could cause
    problems.
    crn, Apr 25, 2008
  12. Fubar Bundy
    Fubar Bundy Guest
    Thanks. Good comment about the pressure. It turns out I was running
    the rear at a lower pressure than recommended in the manual. It
    recommends 38psi. Mine was 30psi. Funny; I would have thought that
    slightly too soft = more rubber in contact with road = more grip (up
    to a point!). Now that I have corrected the pressure, I'll push the
    envelope a bit, when I get a safe opportunity, and see if the
    cornering grip is better.
    Re the age thing: Yes, I can remember having quite old tires on my
    earlier bikes, that had no problem gripping. On the other hand, I see
    pencil erasers that go hard after a year or two, and stater slipping
    on paper and it makes me wonder.
    There is definitely no sign of age-cracking on my tyres. The
    straight-line grip is excellent. In an emergency stop on a dry road,
    the tyres seem almost impossible to make slip.
    Whether it was the slightly low psi that caused the slip remains to be
    seen. Personally I'm suspicious of the actual design of the rear tyre.
    If you consider the cross-section, it seems that if you lean more than
    about 45 degrees, there is (apparently) little rubber on the road;
    you're kind of riding on the sharp corner between the sidewall and the
    treaded part. That seems like a ludicrous situation, but I guess
    Dunlop's tyre designers must know what they are doing. (??) I
    suppose, its conceivable that the cross-section of the tyre has
    changed due to wear. Perhaps it was more rounded when new. But I don't
    think so, going by the tread depth, which is about 4mm everywhere on
    the tyre.
    FB
    Fubar Bundy, Apr 25, 2008
  13. Perhaps the lower pressure allows the tyre to roll sideways more than is
    expected, giving the feeling that it's slipping? Just a thought.
    Mungo \Two Sheds\ Toadfoot, Apr 25, 2008
  14. Fubar Bundy
    120/90-18 rear
    sweller, Apr 25, 2008
  15. Fubar Bundy
    *nods*
    darsy, Apr 25, 2008
  16. Tyres are normally black, aren't they? :)
    Whinging Courier, Apr 25, 2008
  17. Google yourself a nice Cheng Shin Barracuda or similar.
  18. Fubar Bundy
    Maxxis Barracuda actually - same company but different branding.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 25, 2008
  19. Is it? I stand erected.
