tyre recommendation for gsxr1000 ?
Discussion in 'UK Motorcycles' started by jim, Jul 16, 2004.
  1. jim
    jim Guest
    Rear is bald. Front is half worn BT010.
    Stick a new 010 on the rear is obvious answer.
    But if I decdided on 2 new tyres what would you suggest ?
    TIA
    Jim
    jim, Jul 16, 2004
  2. jim
    jim Guest
    I might be able to turn it off if I could be arsed to look.
    But I didn't think sigs needed the approval of others.
    cheers
    jim
    jim, Jul 16, 2004
  3. jim
    Verdigris Guest
    Why bother? You're not going to do that.
    You just wanted to post something about bikes. :)
    Verdigris, Jul 16, 2004
  4. jim
    jim Guest
    I'll put you in the 'doesn't like my sig' column shall I ?
    Jim
    jim, Jul 16, 2004
  5. jim
    All you need to do is uncheck a box - if you can actually drive your
    software.
    A sig is only a sig when defined by a separator or delimiter, which in
    your case should be above your habitual signoff "cheers jim".
    Cheers, Jim.
    Pip, Jul 16, 2004
  6. jim
    Porl Guest
    Pirelli Diablo Corsas. But I have no idea what I'm talking about.
    Porl, Jul 16, 2004
  7. jim
    petrolcan Guest
    the cont known as jim says...
    I'd suggest black round ones.
    Switch this shit off, it's not a fucking email.
    petrolcan, Jul 16, 2004
  8. jim
    Molly Guest
    Nice!
    Molly, Jul 16, 2004
  9. jim
    jim Guest
    How's this?
    jim, Jul 17, 2004
  10. jim
    jim Guest
    ok then, how about this?
    jim, Jul 17, 2004
  11. jim
    jim Guest
    **** it.
    it's clearly not possible to bottom post and have a signature.
    jim, Jul 17, 2004
  12. jim
    Try the tab "Email Manager"
    Untick the box "Certify outgoing messages"
    Job done, grief over.
    Pip, Jul 17, 2004
  13. jim
    petrolcan Guest
    Well done, you updated it. Now get rid of it you useless ****.
    petrolcan, Jul 17, 2004
  14. jim
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, jim
    Yes it is.
    You stupid ****,
    Nigel Eaton, Jul 17, 2004
  15. jim
    Everybody else manages.
    With attributions and all sorts of things - and in the right place,
    too.
    Pip, Jul 17, 2004
  16. jim
    jim Guest
    that's too easy,
    i'm trying to work out how to use outlook.
    Jim
    jim, Jul 17, 2004
  17. jim
    petrolcan Guest
    But Outlook doesn't do newsgroups.
  18. jim
    Ben Blaney Guest
    Whatever you want. I maintain that the average person couldn't tell
    the difference in a tyre test.
    Ben Blaney, Jul 17, 2004
  19. Get a decent newsreader. Outpuke is OK for email but shite for news.
    The Older Gentleman, Jul 17, 2004
  20. jim
    Eiron Guest
    "The average person" can't ride so you're probably correct. :)
    Eiron, Jul 17, 2004
