Tyre quandry.....
Discussion in 'UK Motorcycles' started by Chris H#2, May 4, 2004.
  1. Chris H#2
    Chris H#2 Guest
    Rear wheel on a chop project, got he old rubber off - no damage. New one
    on - no damage. But its proving a larf to get the bead to seat to inflate
    the tyre.
    Took it to two tyre fitters with no joy so far - using their standard
    inflation kit.
    Any ideas on how to sort my rubber out.....
  2. Time and persistance.
    Also several people pushing in the middle of the trad all the way
    around the tyre. A dead blow hammer or rubber mallet to beat it with
    helps, sometimes.
    I used to get Jeep tyres refusing to seat the beads when the tyres had
    been stored incorrectly, especially at 5.20 on a Friday evening.
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, May 4, 2004
  3. Chris H#2
    Mark Olson Guest
    Chuck some cigarette lighter fluid in, set alight, BANG, bead is seated.
    Don't thank me just yet...
    Mark Olson, May 4, 2004
  4. Chris H#2
    Mark Olson says...
    That's what the Icelanders do when they put tyres back on the beads out
    on the snow-fields. It's not uncommon for tyres to become unseated out
    there.
    Lozzo, May 4, 2004
  5. It was somewhere around Barstow, on the edge of the desert, when the
    You need to have the bead rubber tacky - not slippy, just a bit tacky.
    Ordinary soap is good for this; get a lather up and wipe the bead, then
    dry it off a bit with your hand.
    You know those heavy cargo straps, the ones with a ratchet? Wrap one
    round the tread and tighten it up until the bead just seats - then wazz
    in a mighty blast of air, having removed the valve core first.
    Repeat until successful.
    BANG! As the bead seats - and ffs keep your fingertips away from it.
    Wang up the pressure to about 80psi for a few seconds, then release.
    Sorted.
    GS 850 x2 / SE 6a
    Get rid of your SOC/SOB here http://www.sparesorrepair.co.uk/
    Grimly Curmudgeon, May 4, 2004
