Tyre Pressures
Discussion in 'UK Motorcycles' started by colinblake, May 5, 2005.
  1. colinblake
    colinblake Guest
    I have a Bandit 600s and the Haynes Manual says front tyre 33psi and rear
    tyre 36psi when cold. Obviously the pressure increases when the tyre warms,
    so should I stick exactly to these settings when cold?
    I have noticed that depending on the type of riding i.e. in wet weather that
    the tyre pressure increase differs as the tyre warms up.
    I suppose I'm just being a little over cautious as I am a new rider and want
    the tyres to have the best grip possible to build my confidence when
    cornering.
    Thanks
    Colin
  2. just stick to bike manufacturers recommended tyre pressures (usually there
    a label stuck on the bike ) and you wont go far wrong
    Tyre pressures do vary dependant on air temp , road temp weather etc that's
    why they state cold tyre pressures
    steve robinson, May 5, 2005
  3. In uk.rec.motorcycles, colinblake amazed us all with this pearl of
    wisdom:
    If you're that worried I'd stick to what the manual says.
    BTW, garage forecourt tyre blower uppers can vary wildly in their
    readings. Take a decent pressure gauge with you.
    Of course, you can ignore this if you want because I think I only check
    my pressures two or three times over the life of the tyre.
    Whinging Courier, May 5, 2005
  4. colinblake
    Ferger Guest
    Whinging Courier secured a place in history by writing:
    It think this very trusting. I always seem to have one tyre that
    inexplicably loses pressure when the bike's parked up in freezing weather.
    Could be local scroty kids mind...
    Ferger, May 5, 2005
  5. I'll stick to the ones recommended by the tyre manufacturer, if that's okay.
    Dnc
    B1200 - +30bhp ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, May 5, 2005
  6. Whinging Courier wrote
    Well said Sir.
    I check mine when I start falling off the sides of cats eyes. Not quite
    as often as you I think.
    steve auvache, May 5, 2005
  7. In uk.rec.motorcycles, Ferger amazed us all with this pearl of wisdom:
    I tend to do mine just after having them replaced and (maybe) a random
    time or two after that.
    One that likes the cold :)
  8. colinblake
    Kevin Stone Guest
    Nope - stick to the *tyre* people's figures, which for my b600 are 41/36 on
    D207's.
    Kevin Stone, May 5, 2005
  9. colinblake
    Kevin Stone Guest
    And then find yourself miles from anywhere with only 6psi in the tyre,
    thinking bugger, I wish I'd checked. Me myself, I just prod the tyre with my
    finger before riding away, you just know what feels right.
  10. colinblake
    Bear emerged from their own little world to say
    I'm glad I decided to check the GS tyre pressures last weekend. I almost
    didn't bother as they rarely change. I found the rear to be 10psi too low.
    Thinking, "oh shit I have a puncture," I pumped it up with my compressor
    that runs off a 12v accessory socket. I did a lap around the bypass and
    rechecked the pressure. All fine so I went for a bimble through the B roads
    of Monmouthsire.
    I haven't seen any woodpeckers but we do have a suspicious looking carrion
    crow.
    wessie, May 5, 2005
  11. colinblake
    Same here.
    Muck, May 5, 2005
  12. colinblake
    'cos it was fine when I checked it Easter weekend - which was the last time
    I rode it
    wessie, May 5, 2005
  13. colinblake
    Nay, nay & thrice nay - unless you know it's fitted with the OE tyres.
    Different makes of tyres have different construction, different
    compounds etc & therefore need different pressures on the same bike. In
    other words, use what the tyre manufacturer recommends for your tyres
    on your bike.
    This much is very true. A 35psi cold tyre in summer can easily become a
    25psi cold tyre in winter.
    Krusty, May 5, 2005
  14. colinblake
    I would imagine that there is a HSE regulation that says that a
    customer, paying to use such a machine, has to be covered by a safety
    certificate which would involve some sort of calibration.
    Never use them unless I have to. I have a £12 compressor/light unit in
    the car which has a pretty accurate dial guage. I also have an Avon
    branded pencil guage that my dad acquired when he was a HGV driver.
    Ideal for popping in a pocket or tankbag.
    wessie, May 5, 2005
  15. colinblake
    :p
    wessie, May 5, 2005
  16. colinblake
    rb Guest
    How do you know that a particular gauge is accurate then?
    rb, May 6, 2005
  17. All tyre inflators used in garages should meet bs/eu standards however once
    installed there doesn't seem to be any legislation as to how often they are
    recalibrated
    steve robinson, May 6, 2005
  18. colinblake
    rb emerged from their own little world to say
    "pretty accurate" - it's a question of my guages reading very close to the
    guages used by several different tyre fitters over a number of decades
    I doubt any of them are ever calibrated. I doubt a couple of psi is going
    to make any real difference unless you are racing. Pressures vary so much
    depending on weather that we adapt to variations in grip & handling as we
    ride.
    wessie, May 6, 2005
  19. problem I came across though is whilst many tyre manufactures specify
    maximum pressures for each tyre
    many are not bike specific at least the bike manufacturers can give you a
    starting point from which to safely work from if you have no other
    information
    if you know the type of tyre on the bike and the tyre makers do specified
    a pressure for your bike then that is the better figure to work to on that
    point I stand corrected
  20. colinblake
    rb Guest
    Fair enough, I was just wondering what you were basing your statement
    on.
    This I fully agree with.
    rb, May 6, 2005
