Tyre pressures?
Discussion in 'UK Motorcycles' started by fish, Jan 14, 2005.
  1. fish
    fish Guest
    Was out for a ride this evening when I realised that my tyre pressures were
    way to low. I have come home and pumped them up but can't decide what
    pressure they should be at.
    My bike (a Bandit 1200) has 36psi written on the swing arm but this is for
    OE macadams, I now have battleaxe 020 and on the side wall it says 42psi.
    At the moment I have gone some where in between which is much better than
    the 20psi that they were at. Any relevant advise would be really helpful.
    Ta
    Ken
    B12
    BONY#?
    fish, Jan 14, 2005
  2. fish
    WavyDavy Guest
    At a guess it says *maximum* 42psi at <whatever>kg load..... I'd stick to
    the manufacturer's recommended pressures for now if I were you...
    WavyDavy, Jan 14, 2005
  3. fish
    Ginge Guest
    Bridgestone site says 2.5 Bar Front, 2.9 Rear so that's 36PSI and 42..
    Ginge, Jan 14, 2005
  4. fish
    Chas Guest
    My '98 B12 runs on 020's front a rear at 36psi front, 42 psi rear as
    recommended by Bridgestone. I don't bother changing when two up as it
    seems to handle fine regardless.
    On the ride home from buying it, it had 25psi front & 30psi rear,
    interesting handling to say the least !
    Chas.
    Chas, Jan 14, 2005
  5. fish
    Nidge Guest
    snip
    I think its the cold.
    Through out the year I've checked the tyre pressures (OK erratically but not
    too infrequently) and they really never varied until December or so.
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63 BOMB#5
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Jan 15, 2005
  6. fish
    And that, children, is why a wise motorcyclist takes advice from the
    tyre manufacturer, not from the motorcycle factory - the factory can
    never tell what tyres an owner will fit, but the trye lads will advise
    accurately.
    As you are. BT020s fitted to a Bandit 12 should be run at 36 front,
    42 rear. The extra 6 psi in the rear makes a world of difference to
    the turn-in and wet grip, believe me.
    Pip, Jan 16, 2005
  7. fish
    OH- Guest
    I don't doubt that 42 psi might be a good pressure to use. But - the
    figure on the tyre sidewall is definitely the maximum, nothing else (how
    could it - most tyres do not know what bike they will end up on).
    That both numbers are 42 in this case is pure coincidence.
    So to get a good tyre pressure, ask the FOAK or possibly consult
    the tyre company. To find out how much air you can put in the tyre
    the next time you give me a lift on the bike, look at the tyre sidewall.
    OH-, Jan 17, 2005
  8. fish
    joe parkin Guest
    Maximum Inflation Pressure is the highest inflation pressure that the
    tire can withstand. This is not, however, the recommended inflation
    pressure. Inflation pressures should never be below the recommended
    pressure or above the maximum pressure branded on the sidewall. Also
    see Air Pressure.
    from
    http://www.1010tires.com/tiretech.asp
    joe parkin, Jan 17, 2005
  9. It was somewhere around Barstow, on the edge of the desert, when the
    It's not. The pressure on the sidewall on car/bike/van/truck tyres is
    the max pressure the tyre will take in normal use. Most vehicle tyre
    pressures are a fair bit below that for ordinary running.
    I had a tyre fitter a couple of years ago in the habit of putting
    55fuckingfive psi in every van tyre I got from him.... "Why do you do
    that?", I asked... "That's what it says on the tyre", he replied.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 17, 2005
  10. fish
    Rob Rossall Guest
    Have a look on Bridgestone's web site www.bridgestone.co.uk and use the tyre
    selector, it indicates what pressure they recommend for the BT020 on your
    Bandit. I believe it says 2.5 bar for the front and 2.9 for the rear.
    Rob
    GSXR600 K2
    Rob Rossall, Jan 18, 2005
  11. fish
    You might like to have a look at the uk.r.m. FAQ, with specific
    reference to snipping (snipping sigs too).
    But yes, you are correct - for the BT-020 fitted to a GSF1200
    Bridgestone recommend 2.5/2.9 bar ... which converted to psi gives
    36F, 42R - which is what I said up ^^^ there.
    Suzuki recommend 36/36 - but that specifically refers to the standard
    fitment <spit> Michelin Macadams, which apart from their other
    failings (mainly in the grip department) have a stiffer sidewall in
    the rear tyre and will present the same footprint at a lower pressure
    because of this. 020s have a softer sidewall, and need another 6psi
    in order to present the footprint that the bike was designed to ride
    on. Or so I was told by a Bridgestone tech chappie.
    Pip, Jan 18, 2005
  12. fish
    On Tue, 18 Jan 2005 12:05:33 +0000, Pip
    <thread hijack>
    Pip - are you recieving emails from yahoo groups?
    Please add "imo" to above post.
    Champ
    GSX-R 1000, GPz 750 turbo, ZX7RR Endurance Racer x 2
    GYASB#0 BotToS#2 BOTAFO(T|F)#35 WG*#1 DFV#8
    Team UKRM Racing : www.team-ukrm.com
    Champ, Jan 18, 2005
  13. fish
    It is bilge - unadulterated, frozen stiff Scandinavian bilge, in fact.
    I've just nipped out to the patio and taken a straw poll of the rear
    tyres present, not having an 020 to hand, as it were. The figures
    that are quoted here (and being misinterpreted) refer specifically to
    the *maximum load* which is given as ~800 pounds (weight) at /42psi/
    There is no *maximum pressure* stated anywhere on the sidewall of any
    of the tyres on the bikes here. I can't imagine any modern radial
    tyre going pop at 43psi - having seen inflation pressures well into
    three figures when trying to get a tyre bead to seat on the wheel, I
    know this to be true.
    I'd imagine that riding a bike with tyres grossly overinflated would
    compromise the ride quality severely, not to mention the safety of the
    rider, which is why The Law states that pressures must be maintained
    at the manufacturer's recommendation (I'd assume the /tyre/
    manufacturer's recommendation, at that) and that people have been
    nicked and prosecuted for running vehicles with tyres under- or
    over-inflated.
    So, in short - there is no maximum pressure stated, and a GSF1200
    fitteed with BT020s should indeed have 36psi in the front and 42psi in
    the rear. QEfuckingD.
    Pip, Jan 18, 2005
  14. fish
    Fuckme, I dunno. Lemme look.
    <scampers off>
    Pip, Jan 18, 2005
  15. fish
    Yes I am.
    And ...
    WOOHOO!
    Pip, Jan 18, 2005
  16. fish
    Indeed!
    And - get the resin out :)
    Champ
    Champ, Jan 18, 2005
  17. fish
    Indeed. It will be done, no worries.
    However, setting the resin is a heat-dependent process - the colder
    the ambient temp, the more hardener is required. As the ambient here
    atm is about zero and in the garden the wind chill would take it down
    to approaching minus twentyfuckingtwo, this would not be a good idea.
    Adding shitloads of catalyst to ensure hardening works sometimes, but
    produces resin that's as brittle as glass - which, with your record,
    is not a good thing. I'll do it beside the radiator in the living
    room ...
    ... my head hurts. Almost as if I've been hit repeatedly
    around the temples with a bit of fourbytwo. Odd, that.
    Pip, Jan 18, 2005
  18. fish
    <hands head>
    You're not wrong.
    Aye. It is currently residing in the tray.
    If I don't get a reply I assume it's because the addressee thinks I'm
    a ****.
    Pip, Jan 18, 2005
  19. fish
    Yes, I recall you saying that winter is not a good time for playing
    with fibreglass.
    Hey, people pay good money to get that buzz!
    Champ
    Champ, Jan 18, 2005
  20. fish
    Good excuse to wedge cardboard over the garage window and get the
    donated Calor heater stoked up ... if the CO don't get me the
    explosion caused by ignition of fibreglss fumes prolly will.
    The buzz above, gained from working with fibreglass in a confined
    space is even betterer - but the hangover is a doozy!
    I spent an afternoon on a rally car a few years ago, using fibreglass
    resin and tissue to seal the rear firewall between boot and cabin
    (where the rear seat used to live) and then Hammeriting said firewall
    and boot inner. This meant I was bent double, heid in the boot, for a
    few hours.
    They found me in the inspection pit beneath the car, asleep with a big
    smile on. Head fucking hurt like a bastard the next day, though.
    Pip, Jan 18, 2005
