tyre changer/bead breaker
Discussion in 'UK Motorcycles' started by in2minds, Jan 21, 2004.
  1. in2minds
    in2minds Guest
  2. in2minds
    Catman Guest
    <fx books table at Restaurant at the end of the universe>
    I'll let you know how many last week, OK?
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    www.cuore-sportivo.co.uk
    Catman, Jan 21, 2004
  3. in2minds
    Petel Guest
    Bead breaker.......Anglegrinder or hacksaw and benchvice.
    You just need to get the bloody tyre off without damageing the rims right?
    Refitting......Compressor up to 40psi, make sure the O.E paint dot is next
    to the valve and orientation is correct.
    Inflate.
    If the tyre dos`nt "pop" into place you need a Bead-expander.....
    Or some rope wrapped around the tyre and a tourequet, a couple of rachet
    straps, anything to expand the tyre beead into the wells......inflate.
    Furniture polish makes a good lube for fitting but for pedants use a
    mold-release agent or PTFE spray as used in GRP manufactureing.
    Balancing...best left to tightrope walkers..or use two stools,the
    axle,roofing lead,and Zen;-)
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Jan 21, 2004
  4. in2minds
    Lozzo, Jan 21, 2004
  5. in2minds
    Petel Guest
    Anglegrinder was a bit OTT but the bench vice and surruptitous cutting with
    a hacksaw does work.
    I`ve done it on 170/60 ZR 17`s and as long as care is taken it works.
    The object is to get the tyre off with no damage to the rim?
    Stick it on one of Kwick-fit (sic) machine`s and watch it chew the alloy.
    For speed I use an anglegrinder just to "break the back" of the tyre, never
    getting close to the rim.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Petel, Jan 21, 2004
  6. in2minds
    in2minds Guest
    "They have an online catalogue too :"
    I know, I was looking for a comparison price from other traders.
    Les
  7. Pikey bead breaker...
    Hole in wall, spade, 8 feet of 3"x3".
    Lay wheel flat, place spade upright on bead, insert wood into hole and
    over the shoulder of the spade.
    Sit on wood.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Jan 21, 2004
  8. in2minds
    Ginge Guest
    Alex Ferrier.
    Ginge, Jan 21, 2004
  9. Yeah, same to you.
    pseudoplatypus, Jan 21, 2004
  10. Actually, the first time I saw this done, the fella was a lithe, slim
    chap not unlike yourself.
    Well, instead of the wood - two pieces of scaffold slotted together, a
    spade, and a handy hole can be found anywhere.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 22, 2004
  11. in2minds
    To make the extra sidewalls I had on the bangers [1] the best tool was an
    old serrated bread knife. Hacksaw was too fine and a stanley knife 'dug
    in'.
    [1] It was common practice to cut out the sidewall of an old tyre and
    sandwich it between the rim and tyre on the wheel. This would cut down
    on the sidewall damage and punctures. The wheels needed tubing.
    I used to buy the chaps at the local tyre depot a catering sized Nescafe
    tin for every eight they got the apprentice to make up for me.
    Apparently it was quite tricky and required a perfect technique.
    sweller, Jan 22, 2004
  12. in2minds
    If only...
    Champ, Jan 22, 2004
  13. Is that bad news? Single again?
    William Grainger, Jan 22, 2004
  14. in2minds
    heh. No, not at all. Just cheap smutty humour.
    Champ, Jan 22, 2004
  15. The best kind, really.
    GS 850 x2 / SE 6a
  16. in2minds
    deadmail Guest
    You do know that we search on "Team UKRM" don't you?
    deadmail, Jan 22, 2004
  17. in2minds
    flook Guest
    Minus the hole in the wall and suitable wood that methoid served me admirably
    for the supermoto racing. Place spade near rim on the tyre and apply far too
    many kilos of body weight on the top of the spade blade and wait for the bead to
    unseat. I plan on applying the same technique this year.
    flook
    flook, Jan 23, 2004
  18. in2minds
    flook Guest
    My local Riossi always used to do this for free for me. Shame they've gone
    titsup. [1] Having said that, my local National tyres will change two tyres
    (loose wheels) for a fiver so it;s worth asking.
    Sometimes. Other times it's possible to spend 30minutes cursing, stabbing
    oneself with tyre levers and sweating.
    You in Derby Phoenix this year Daz? If so, see you there. :)
    flook
    flook, Jan 23, 2004
  19. ITYM "the only kind you will find on UKRM"..
    Phil
    Phil Launchbury, Jan 23, 2004
