Tyre bead problem
Discussion in 'UK Motorcycles' started by OH-, Mar 7, 2005.
  1. OH-
    OH- Guest
    Yamaha TT600R winter overhaul.
    OK, so I got the rear wheel sorted and the tyres off both
    wheels. Mounting the rear tyre (that was a bitch to get of)
    was easy. The front tyre (that more or less jumped off
    the rim voluntarily) will not seat properly.
    This is a 90/90-21" tyre with a tube on a takasago spoke
    rim. I get it on the rim and one side plus 3/4 of the other
    seats perfectly. I have emptied and filled the tube a
    number of times, I have used a lot of tyre mounting "soap",
    I have tried with the tyre rotated to different positions
    on the rim. I tried bouncing the wheel on the floor and
    banging on the tyre with a mallet. It is not always the same
    part of the tyre or rim that is involved in the problem.
    How much pressure can I use safely, the tyre makers
    web site says 45 psig but I've already been at 60?
    Can I just go riding and hope some miles on rough
    roads will cause the tyre to seat correctly?
    What am I missing here?
    OH-, Mar 7, 2005
  2. OH-
    Dave Emerson Guest
    *Don't* try riding with the tyre unseated.
    60psi (unloaded) should be safe but normally it's not just a matter of brute
    force,
    something is stopping the rim getting into position.
    The tyre should be marked with a dot to align with the valve housing, for
    best balance.
    Are the tube and inside of the tyre smooth and well dusted with talc/chalk?
    Sometimes it helps to bounce the wheel with only 10-15psi in it to get
    things settled.
    Dave Emerson, Mar 8, 2005
  3. I've been up to 75-80psi on occasions, and it's been OK. I once tried
    going higher, and IRC went up to about 90psi and then the pump connector
    blew up.
    Seriously, I remember reading about a Continental biker tyre destruction
    test when they blew the tyres up to something stupid like 150+psi (the
    wheels were held underwater to absorb the explosion and debris if they
    went bang) and they held.
    Use *lots* of tyre soap and take it to 80psi.
    It won't. Trust me.
    The Older Gentleman, Mar 8, 2005
  4. OH- pretended :
    It depends what you mean by not seating properly...
    If you mean the line on the edge of the bead is hidden behind the rim
    in one spot, then try more air pressure. I have had this happen. Being
    a little timid stopped at 60psi and took it to a tyre fitter. All he
    did was take it up to 80psi and it all sorted itself out with a sharp
    pop as it dropped into place.
    I again struggled with a later tyre, but just did what the tyre fitter
    did and took the pressure up some more until it dropped into place.
    Harry Bloomfield, Mar 8, 2005
  5. OH-
    OH- Guest
    <snip>
    Thanks for the advice and encouragement.
    Debriefing: I finally won over the tyre by sheer
    stubbornness. All that exercise with the hand pump
    was probably good for me.
    Just to prove that I'm not very good at these
    things anymore, I managed to pinch the tube but
    that is sorted as well.
    OH-, Mar 10, 2005
  6. Heh. Been there, done that.
    The Older Gentleman, Mar 10, 2005
