Two questions in one ...
Discussion in 'UK Motorcycles' started by SD, Apr 6, 2006.
  1. SD
    SD Guest
    1. Are hazard flashers included in an MOT test?
    2. What's the FOAK's recommendation for a photo printer/scanner?
    SD, Apr 6, 2006
  2. SD
    SP Guest
    JFG for VOSA and look it up.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Apr 6, 2006
  3. SD
    SteveH Guest
    AFAIK, although there's no requirement for hazard lights, if fitted,
    they must work. Easy solution is to remove the button.
    Almost any HP Photosmart. We've had a PSC2100 series for quite a while
    now and are very happy with it. This appears to be the equivalent in the
    range to the one we have:
    http://www.johnlewis.com/Computing/Printing+and+Scanning/+Printing+and+S
    canning/+Printers+/230222100/Product.aspx
    Out of stock online, but might be available in store.
    SteveH, Apr 6, 2006
  4. SD
    raden Guest
    If they are fitted they must work
    I have an Epson Stylus DX4800 which is good, but Epson consumables are
    not the cheapest
    When you buy any printer, look at the cost of the consumables as well as
    the cost of the printer itself
    raden, Apr 6, 2006
  5. SD
    Christofire Guest
    My dad's hp photosmart 3210 is pretty decent. Copier, printer,
    scanner, card reader, lcd display (handy to print from card), network
    port.
    It's quite quick, and looks pretty good on the prints too.
    http://h10010.www1.hp.com/wwpc/uk/en/ho/WF05a/5043-5527-7369133-7369133-
    12229140-12229166.html
    Christofire, Apr 6, 2006
  6. SD
    Ali Hopkins Guest
    And then buy cheap clones of consumables.
    Ali
    Ali Hopkins, Apr 6, 2006
  7. SD
    Ali Hopkins scribbled on the back of a napkin:
    And then buy cheap clones of consumables.[/QUOTE]
    This is not necessarily a good idea for quality photo printing. You
    want at least decent clones of consumables, or if you're printing a
    lot, a continuous ink system (which is a lot cheaper to run than
    cartridges).
    Timo Geusch, Apr 7, 2006
  8. SD
    SD scribbled on the back of a napkin:
    What are you trying to scan? Colour prints?
    Generally you're better off scanning the neg as most mini-lab prints
    from the usual suspects (ie, not a pro lab) are pretty crap. Flatbed
    scanners suck dead donkeys when it comes to scanning 35mm so you'd be
    looking at a proper film scanner.
    Budget recommendations are either the Minolta Scan Dual IV (especially
    if you scan transparencies as well) or the PlusTek OptikFilm 7200i
    (which gets good reviews and is very cheap for a dedicated film scanner
    but doesn't have the D-max to scan transparencies properly).
  9. SD
    Buzby Guest
    I've given up with printing my own photos - I can't compete with the
    photobox prices!
    Buzby, Apr 7, 2006
  10. SD
    Greybeard Guest
    2} I have a Canon Pixma MP760. All in one and I'm extremely pleased. Scans
    35mm negs as well!
    Quite cheap to run using compatible cartridges as they are very cheap on
    ebay. Also the colours are all separate. and it has 2? black carts.
    Recommended 10/10 by me.
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stg 2. Big Boy!)
    Trumpet Trophy 1200 -96, (The Barge) for rainy days
    ukrm@foxtails[dot]co[dot]uk
    *** Free account sponsored by SecureIX.com ***
    *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
    Greybeard, Apr 7, 2006
  11. SD
    SD Guest
    Erm. Well, it passed.
    Giving it the once over beforehand - I pushed the hazard switch, as
    you do. It wouldn't go off. push; push; push for ages - it goes off.
    MOT done, trundle home.
    Oh, well, that WD40 must've worked. <push>
    Can I get the bloody thing to turn off? Can I arseholes.
    Screwdriver fun tomorrow, then, or my trip to Kent on Sunday could be
    a little awkward.
    I guess it didn't get tested - or I was very lucky.
    SD, Apr 14, 2006
  12. SD
    SD Guest
    Well, it wasn't - it was as good as a trip to see one's sibling can
    be. Even my great-nephews talk to me now.
    It might be a slow wallowy old barge - but the big lump's definitely
    got a certain charm about it.
    Those fork bushes need doing soonest, though.
    SD, Apr 17, 2006
  13. SD
    SD Guest
    Went for the MP800, in the end. Gold Award winner in Digital Photo
    mag, and only £185 from dabs.com - £250 from Jessops.
    Ta for all the help, chaps.
    SD, Apr 17, 2006
  14. SD
    SD Guest
    and b&w. (the MP800 does negs, too, handily)
    Given some of the pictures were taken in the 1930s, getting hold of
    the neg could be tricky. :)
    SD, Apr 17, 2006
  15. SD
    Check out the quality of the neg scans, though.
    Crap filing system, eh? :)
    I know that particular problem.
    Timo Geusch, Apr 17, 2006
