Twin Headlight Conversion
Discussion in 'Motorbike Technical Discussion' started by Steve, Mar 1, 2004.
  1. Steve
    Steve Guest
    Just got a much modified FZ750 on the road having had it in storage for a
    while (Came to me modified and this is the first time I've used the thing)
    only to find that it blows both stop and tailight filaments of the rear
    bulbs with quite stupendous regularity. One bulb even melted the plastic of
    the rear light housing before vapourizing its filament. Since part of the
    mods carried out on was to slap on a YZF fairing with Twin 60/55w my
    immediate thought is that simply wiring the headlights up in parallel was
    probably not the way to go. I'm not, however, an autoelectrician so I was
    wondering if anyone could provide info on what should have been done to make
    this set up work or is the layout as described alright with the problem
    lying elsewhere? TIA
    Steve, Mar 1, 2004
  2. Check the system voltage.....Some probability that the voltage regulator
    is burned out your bulbs are seeing in excess of 15 volts (could be real
    high even). Do this soon as the next thing that'll go will be your
    ignition and any maybe other electronics that you have onboard.
    G. Skiffington, Mar 1, 2004
  3. the thing) only to find that it blows both stop and tailight
    yep...its regyoulater is not the full quid...you will need another one
    wiring the headlights in parallel should be fine, although if you use both
    on low beam people may assume you are on high beam and flash you
    most annoying
    fulliautomatix, Mar 3, 2004
